Tape Decks
Problem for Tape Decks
Generic problem for all Tape Decks
Cassette deck not working
By baubau on Jan 03, 2008
Hello -
I have the below-mentioned tape deck which I've used very little in the past six-or-so years. Recently, when I tried to play a cassette, the machine wouldn't run. It displayed some lights but the tape wouldn't move. After a few seconds, the play arrow would go out. When I tried to remove the tape, the door wouldn't open.
After opening up the case I was able to release the latch and remove the cassette. Everythiing looked good inside: the belts and rollers looked fresh... nothing that I could notice looked amiss.
I've just noticed on ebay that some one is selling a machine just like mine with what sounds like the same symtoms:
http://cgi.ebay.com/Sony-TC-WR670-Dual-Cassette-Deck_W0QQitemZ230207931875QQcmdZViewItem?IMSfp=TL0712300930a36859
Any help would be greatly appreciated. It's given me years of good service and I would like to continue using it from time to time.
Thanks, in advance.
David
Comments:
Jan 18, 2008
- Thank you for your advice.
The belt does indeed seem to be slipping. I'll try to clean as you suggested. I think I also got grease on the belt and pulley as I poked around. It is quite tight in there.
How would you suggest changing the belts, and where do you buy them? Do you completely disassemble the drive mechanism?
Thank you, in advance, for your reply.
David
Jan 26, 2008
- Thanks again for your advice. I was able to find two new belts andreplace them.
I had forgotten how well this machine works. Thanks to you it has a new lease on life.
David
Best Solution
posted on Jan 14, 2008
Helpful)
robotek
Rank: Guru
Rating: 91%, 1192 votes
Hi, with the lid off operate the unit and see if drive still gets from the motor to capstan flywheel. Sometimes even although belts look ok, the have a buildup on the drive surfaces that will prevent it from applying enough tractive effort to the flywheel to engage the rolling mechanism. most of the hard work in ooperating the transport occurs when you select a function as the transport engages cam gears and followers to provide mechanical movement to engage the operation you have selected. You can fix this by cleaning the belt by running it across a cotton bud dipped in solvent (i use acetone, or iso alchohol),but replacing the belt is generally a longer term solution. If you need more advice then hitme back... happy to help
Comments:
Jan 26, 2008
- no worries... glad to have helped. happy dubbing :)
Was this helpful?
Yes
No
Popular Solutions for Tape Decks
Questions and Unsolved Problems for Tape Decks
Answer
I have own a Nakamichi CR-1 tape deck recently. The first time I have played it was no problem and... (More)
Answer
will the door on the casette deck come off for head cleaning? If so, how?
Answer
Will not transfer from one deck to the other when playing with tapes in each side. When this... (More)
Answer
My alesis adat type II started showing error 1 and stopping in the middle of playback and recording.... (More)
Answer
Our Pioneer DVR-RT400 will play video cassettes but will not record. Safety tabs are intact on the... (More)
Describe your Tape Decks problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Tape Deck Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
