Question about Panasonic TH-50PHD8UK 50 in. Plasma Television
Low def pictures on high def flat panel
Hi Def sports broadcasts on hi def channels are extremely sharp and detailed but other than that, viewed from any distance, the picture is lacking in detail -- like sitting in the third row at the cinema. Even
TV studio broadcasts are fuzzy, although all lettering, such as display text or subtitles is razor sharp. Is that the state of this industry? When I saw this unit on display in the store a few years ago, it showed stunning detail, but I suppose in-store set ups are special. I use video component connections and the source is a cable provider with a "high def" box. Is there any way to improve this disappointing performance? I don't think it is the unit but the source: garbage in - garbage out. One other exception is material from public television -- most of that material is tack sharp. Other so called Hi Def channels are fuzzy -- bad enough that my friends wonder what is wrong when they see it. Any ideas? Please advise.
    Sergeant:
  • 264 Answers
Do you have your video pluged in to the tv or any thing elc if so unplug the video any see if that work or it could be your ampifier let me know how you get on thanks
Posted on Jan 03, 2008
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture is schinking in on both sides
the picture is narrowed on the sides when you are not on a high def program.
commercials will often be standard def even on a high def channel.
check you cable or satelite box setting to "stretch" analog programming automatically.
Apr 12, 2011 | Audiovox PLV16081 8 in. LCD TV
I have an Apex digital 32" LCD TV Model LD 3249 and Serial #36056009262 Is this a high definition TV
Yes. 720p High-Def capable.
Remember you have to have a High-Def signal source to actually view High-Definition video. This means local broadcast TV in HD or digital cable TV with HD service and a HD channel or satellite or a Bluray Disc.
Mar 15, 2011 | Televison & Video
Picture blacks, tv needs to be turned to bring picture back. wii games do not go black
This is caused by your QAM decoder on hi def Sharp sets. You need to rescan for channels, turn off your TV then turn it back on to set to save the channels.The problem lies in the Tuner board and some Hi-Def signals can change frequency slightly due to improperly shielded cables etc. Verify that all of your cables, especially the Cable TV wire are firmly seated on your set. An improperly grounded cable television wire can wreak all kinds of havoc on reception.
Oct 29, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
Won't broadcast in hi-def with component cables
I have a BENQ PE8700 also. Charter Cable just replaced my Hi Def Cable Box and now I only get the non hi-def channels. I get the sound on the Hi-Def channels only. My projector is hooked up with the DVI Cable. Did you ever find out why you were not getting HI DEF?
Aug 07, 2010 | BenQ PE8700 Multimedia Projector
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
SHARP LC-46SB54u Problem
I've seen this problem after changing high-def channels sometimes. I found if you switch to a low-def channel, then back, it stops jumping. This causes it to re-sync. An annoyance. Too bad there aren't any firmware updates to be found.
Feb 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Panasonic TH-50PHD8UK 50 in. Plasma Television Logo
105 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
