Question about Hotpoint RGB745 Gas Kitchen Range
Oven My oven will only light, when I move the oven latch door handle to the allmost lock position, and hold it there. Once it returns to the unlock position the oven goes out again.
    Master:
  • 619 Answers
The lock spring unhook back cover must open / gas must be shut down. before open back cover., spring might cut spring hook corroded possibility door door lock malfunction.
Posted on Jan 05, 2008
How do I lock door for self cleaning
Some ovens have a latch handle between the top of the door and the actual range top that you have to push sideways to lock. May also be a lock button you have to push in while moving the latch handle.
If you don't see the latch handle, The lock system may be the hidden type that should lock automatically when set to clean. Once the oven is set properly for clean, a motor will latch the door by itself. After the oven gets close to clean temperature, the latch gets locked out and the door will not open until the clean cycle is complete and oven cools down to normal room temperature again. This is a safety feature so you can't open the door while the oven is at clean temp (about 850 degrees). Hope this explains enough. If door never auto latches, could be a problem with the latch/lock system and motor.
Mar 29, 2015 | Ovens
1997 lincoln continental
Check the latch itself (on the door) is in the open position, ans didn't accidentally flip to the closed position. This has to be open so it can fit over the stud in the door jamb, where it flips over the stud to latch the door.
If so, while holding door handle (as if you were trying to open/unlatch door), flip latch open, with a finger or a screwdriver.
Jun 24, 2013 | Cars & Trucks
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
Both door locks do not work properly. I can only open the drivers side door from the inside. And the passengers side door will not open at all. This is on a 1999 Ford Explorer Sport.
Do any of the door handles inside or out feel sloppy (when you pull on them does it feel like there is nothing connected to them)?
If so that the levers on the latches are probably rusted up and sticking. Say for example the outside door handle lever that is attached to the door latch is stuck half way in the open position it will not allow the door lock mechanism to lock or unlock. The door will still latch and stay closed because the lever will not be stuck far enough to release the latch mechanism from hold on to the striker.
I have had pretty good luck removing the door latch (the part that actually holds the door closed) and soaking in penetrating lube and working all the levers until they move freely.
As far as the door that doesn't open I suspect it is stuck in the lock position and one of the handle mechanisms is in the partial up position. Again the symptom would be a sloppy door handle. That lever will need to be put back in its normal resting position before the door can be unlocked. This can be done with a slim jim. Once you have the door panel apart on the door that still opens you will be able to see the parts you need to move. You can then use that knowledge to move those parts on the other door that doesn't open.
If you don't have any experience with a lockout kit (i suspect most people do not) that that's the best way I can describe how you can do this yourself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 29, 2010 | 1999 Ford Explorer
My door on my n01 grand am gt 2 door will not close. the thing in the door is like stuck locked? what can i do
Manually push the lock button into the UNLOCK position. Now HOLD the OUTSIDE DOOR HANDLE in the OPEN position while at the same time, moving the DOOR LATCH into the open position. Hope this helps
Jun 15, 2009 | 2001 Pontiac Grand Am SE
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Oct 17, 2007 | Ovens
Hotpoint RGB745 Gas Kitchen Range Logo
109 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
