Question about Flat Panel Televisions
New samsung lcd hd tv has a blurry picture
We just got a new 52'' lcd tv and right after we set it up the was immediatly a blurry, blocky picture.
plz help
SOURCE: reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
Posted on May 30, 2008
SOURCE: Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Posted on Apr 30, 2009
  • 22 Answers
SOURCE: What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Posted on Sep 21, 2009
  • 610 Answers
SOURCE: Samsung 52 inch LCD - no turn on just clicking
most likely the power supply board has failed, but it could be the main board as well. call 1-800-samsung for nearest service center.
Posted on Nov 25, 2009
Testimonial: "I open the TV (Samsung 52" lcd full HD) up. I noticed 2 1000uf 10v caps has expanded at the top. I replaced the 2 caps (77pence each). TV now work."
SOURCE: 52" Samsung LCD will not turn on. Blue light is on
I had that problem--POWER SUPPLY. IT COST ME $300 to put in the fix kit, and now 27 days later, my screen is bad. it has verticle lines on the right side of the picture. the tech said it is a bad panel so go buy another tv!
Posted on Dec 29, 2009
  • 26 Answers
SOURCE: how too make work the small pip on a 52
All pip or pop features must have 2 seperate and distinct video sources. With your tv you can choose to have cable split with a 2-way splitter and one feed to cable box and the other directly to a second ant connection on back of tv. If you only have 1 rf input on tv then your second source would have to be from a vcr or dvd etc. once you have 2 seperate sources going you select pip and choose what source you want and both main screen and pip screen will appear. obviously you will only have audio on main screen so if you want to hear pip you have to switch back and forth.
Posted on Dec 31, 2009
0 characters
1 Points
My picture is blurry,and words are blurry,what do i do
A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Jan 24, 2015 | Flat Panel Televisions
I have a samsung lcd lnt4661fx/xaa tv and the picture is all blurry, how does this get fixed and how much will it cost me
Does it improve when the set warms up? Is it the entire screen or just the left or right side? These sets are notorious for faulty LCD panel tabs which causes blurry/delayed picture problems.
Mar 11, 2013 | Samsung Flat Panel Televisions
Why is my tv blurry and distorted? We have reset all settings. Still blurry.
It looks like a light shining on the screen when you were recording the problem.Also, you are taking the picture from a bad angle for lcd types of tvs.Try a new recording,also get the tv on an HD channel for a better,clearer picture.Many hd tvs look bad on non HD channels.
Nov 14, 2012 | Flat Panel Televisions
My picture is to the left of the screen and the picture is zoomed in
check the zoom settings and look for the option to move it to the right. this can usually be found on the same location for the aspec ratio
Dec 04, 2010 | Samsung LN52A580 52 in. HD-Ready LCD TV
Some HD channels won't work on new Samsung tv.
Some hd channels can only be viewed by watching thru a cable box. If you are using a cable box check with your cable provider to see what the issue is.
Dec 23, 2009 | Samsung LN52B550 52 in. LCD TV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Blurry picture when hooked up to direct tv.Why?
try lowering the sharpness on your tv, because if the sharpness is to high it will make NonHD objects look blurry, also try changing the input cable or type of input.
May 20, 2009 | Element Electronics FLX-2610 26 in. LCD...
Toshiba 52" REGZA has a grainy picture
There is no easy (read: cheap) solution for this. Especially because your TV is so big, the only thing that will look good on it is something that plays at the very least 720p HD output.
I don't know what your DVD player model is, but you want an upconverting DVD player, and even then, the quality will not be full HD. The only thing that is full 1080p HD on the market today is Blu-Ray, and game consoles like XBox 360 and PS3.
As for the sports, it depends on the TV you bought. If the deal was too good to be true for a 52" TV, you probably got one with a low Hz, or a high refresh rate. This means that the images played don't update quick enough for high motion video like action movies and sports, which is why it's blurry. Mine has a 3ms response time, by comparison.
Hope this helps, please rate me.
Feb 21, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Feb 24, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Picture edges blurry
There is a setting labeled cropping... turn it on.
Nov 19, 2007 | Olevia LT32HVM 32 in. LCD Television
Flat Panel Televisions Logo
550 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
