Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Problem for Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Have 2 gasoline inputs to my walbro carbrator. The
By kq0n on Nov 03, 2009
Have 2 gasoline inputs to my walbro carbrator. The one on the bottom closest to the diaphram side leads to the prime botton. The one on the otherside leads directly to the gas tank. When the prime button is pushed gasoline flows out the hole in the cover plate over the diaphram. Are the gasoline lines connected properly? If so, is there a hole in the diaphram, and the fact it needs to be replaced.
Best Solution
posted on Nov 03, 2009
Very Helpful)
mdmcdowell
Rank: Guru
Rating: 91%, 53 votes
Sounds like you have the lines connected incorrectly. Make sure that the bottom of the carb is connected to the inlet side of the primer (take the lines off and with one of the ports covered with your finger push the bulb, if it collapses and doesn't return then that's the suction/inlet of the bulb). The other side of the bulb needs to be connected to the gas tank. The other side of the carb needs to go to the filter side of the gas tank.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
mrfixit-jerr
Rank: Guru  Garden Tools  Expert
Rating: 94%, 7497 votes
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly.hope this helps,MrFixIt, oh could you please rate this solution,thank you.. this is for most fuel line trimmers~~~
Was this helpful?
Yes
No
Popular Solutions for Ryobi 30 Cubic Centimeter
Questions and Unsolved Problems for Ryobi 30 Cubic Centimeter
Do you recommend Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer?
Answer
Answer
How to fix my Ryobi Wipper Snipper - Model# RLT30CD? Hi, I having been using the bump feed and all... (More)
Answer
I need the torque specs for 26cc trimmer engine head bolt. Thanks!
Answer
I have a Ryobi petrol line trimmer with curved shaft. Installed reeleasy head what a fiasco! Spool... (More)
Answer
I would like a manul with instruction on who to tread my trimmer.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ryobi 30 Cubic Centimeter...:
Top Leaf Blower Experts
Rank: Guru Guru
Solutions: 3950
Experience: ten years experience,school trained,own business
Ask Me
Find more Leaf Blower Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
