One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it. You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE. Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason. Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear. Known as "The Click Of Death"
Cables for USB are standard, there's really no USB 1 or 2 cables, just USB cables. So, chances are the issue isn't the type of cable but maybe the lack of power.
Most computers with USB 2.0 ports supply enough power through these ports to run a passport, but not all. Also if you plug the device into an older PC with USB 1.1 ports they don't provide enough power from a single port.
The solution is to try using a double headed USB cable(2 on the PC end and one for the drive). If power is the issue plugging in two connectors to the PC will solve it. If this doesn't work, reply back as you may have a more serious problem inside the Passport enclosure.
Hope this helps FixYa,
Chris
Was this helpful?
Yes
No
Popular Solutions for Western Digital WD Passport
Western Digital WD Passport 250GB Portable Drive 250 GB Hard...
is there a Western Digital storage solution compatible with Macs and PCs. We mainly have Macs and...
(More)
is there a Western Digital storage solution compatible with Macs and PCs. We mainly have Macs and want an external backup solution / hard drive. We also want portable hard drives that can also work on a PC. Can you make suggestions please. Do you have any feedback regarding Macnally v Western Digital. Thanks heaps, Tara
I purchased a passport elite and it is showing an error message on my laptop stating it is not...
(More)
I purchased a passport elite and it is showing an error message on my laptop stating it is not compatible. I have a toshiba vista system
