Question about EliteGroup A907 Notebook
Flickering display Hi, my desknote display flickering whether when Win98 installation. Also occur when using WinXP. Then after a few moment, it'll hang. But when accessing the BIOS, the display seems OK. Suspected not LCD because it also happen when attaching to the external monitor. Please help me how to fix.
  • badz Jan 08, 2008
    my screen display is flickering whenever I open an internet
  • Anonymous Jul 07, 2008
    i cant not my display setting to 32 bit display
Buy a new one!
Posted on Mar 07, 2008
  • 233 Answers
If it happens with external monitor then it's probably video card.
most likely a cold solder joint on the board. OR if it's a plug in type board it might just need to be re-seated.
Posted on Jan 05, 2008
What can be the problem when my message box is flickering? From the moment I have my new phone, the evelope is flickering?
It indicates that you have messages saved on your Sim Card memory. Open the Menu, and then open up the Messaging (Message), in the main menu of your Messaging, press "Option" and select "Sim Messages", this will direct you to the Sim Card messages, from the delete them or move them to the phone memory. Once they are moved or deleted, you'll no longer see the envelope icon blinking except when there's unread messages.
Hope this helps.
Good Luck.
Thanks for using FixYa.
Jul 14, 2011 | Nokia 5230 Cell Phone
Hi, The screen flickers at the taskbar end every 2 second. Lenovo R400, 7443-TGA. This my second time using the lenovo thinkpad product with the same problem. Why lenovo screen always problem. I never.....
Hi techsyss,
I see that you are having issue with your taskbar flickering as you mentioned in the notes.
I would be more than glad to assist you regarding your concern.
>Try to reinstall your Video Drivers on the machine or poassibly update the Video drivers.
>Try chagning the resoltion on your system try setting it to a resolution that is lower than what you actually have and see if the flickering will still be occuring.
>Also try to boot into the BIOS of the machine to see if the Flickering occurs in BIOS as well, to boot into BIOS upon powering the machine keep on tapping F1 till you get a blue screen saying phoenix BIOS as long as the word BIOS is there you are in the right page. just check if the flickering happens there, if it does then the issue is not software but most likely hardware it can be the LCD itself or the Cable conenction of the LCD to the Video on the motherboard.
>if the flickering is present in BIOS most likely you will need to have the system serviced for proper repairs and diagnostics.
I hope this helps.
Have a nice day,
Apr 25, 2011 | Lenovo Elite ThinkPad R400 Notebook
Flickering lines on the screen
I suggest try to connect your machine to an external display and see if its having also a flickering lines, if not it means the lcd display have a problem and try to load also to BIOS and see if its also having flickering lines, if its having also flickering lines means that the lcd is faulty.
Hope it helps. =)
Apr 20, 2011 | Samsung N120-12GBK Netbook
Display is flickering and goes out and the screen become black. I attempted to hook up external display and get the same results. I think the issue may be a bad inverter card? System has winXP Home...
try tapping the LCD bezel, if you sense that the LCD would flicker, your hunch might be correct about the bad inverter card. it would also depend if the LCD type has an inverter. or worse case scenario - LCD is already failing...
Hope it helps!
Oct 26, 2009 | Gateway MX3215 Notebook
Screen flickering with nvidia driver
your problem may not be your video card ; check the resolution abilities of your may be exceeding the parameters of your monitor
Apr 15, 2009 | Computers & Internet
Not supports bi-directional printing on win98 + winxp network
this is compatability problem. You should install your printer on Windows XP system. Then make it share for all. I think it will print from both 98 and XP. try this.......good luck.
Mar 26, 2008 | Canon LASER SHOT LBP-2900 Printer
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Dual boot
hi wtm78 this is nichu,
it is impossible to install win 98 after installing xp,if you want to install win98 you must remove the winxp and then first install win98 and later you can install winxp,
basically it is impossible to install a lower order software when xp is already installed,in your case it is the same
there will be no things like dual boot or anything ,after booting your system asks whether you want to work with win98 or winxp.
be cool.
take care
bye and have a nice day.
Nov 08, 2007 | Computers & Internet
EliteGroup A907 Notebook Logo
67 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
