Question about Microsoft Xbox Console
Xbox 0mb???????????????????? my xbox has a avaluanch hard-drive in it with over 160GB of memory in it and all tricked out front (screen, avaluanch symbol,etc.) and i only downloaded about 16 games on it and when i went to download again it said on screen that i had 0 Mega-bytes left and won't let me download any movies,games,or music but when i checked the remaining memory it said over 143,000mb left. what should i do. and it won't read my disks.
  • javern nolan
    javern nolan Jan 06, 2008
    it wont reasd my discs either it even wont read the brand new ones
    President:
  • 4,402 Answers
Did you create a g drive?
you also have room on "f "and "e" drives
Posted on Jan 08, 2008
6ya staff
SOURCE:
Serial no 359146794305 what is its capacity
Microsoft has shipped numerous variations of the Xbox 360, with the major difference between each one being the hard drive size. As a result, your Xbox 360 can have a hard drive size as low as 4 GB and as high as 250 GB. If you're unsure of the size of your Xbox 360's hard drive, or just want to see how much space is remaining on it, you can check from the Device Options screen. This screen is accessible from the Xbox 360 dashboard when using any Gamertag.
Step 1 Select the "Settings" tab from your Xbox 360's dashboard.
Step 2 Select "System" and select "Storage" from the onscreen list.
Step 3 Highlight your hard drive from the onscreen list. By default the name of the hard drive is "Hard Drive."
Step 4 Press "Y" on the Xbox 360 controller to access the Device Options screen. The right side of the screen lists both the overall size of your hard drive under "Capacity" and the remaining amount of space under "Free Space."
Tip
  • From the Device Options screen you can also give your hard drive a custom name, clear the system cache or transfer content to another memory device.
Oct 06, 2015 | Microsoft Xbox 360 Console
Tip
How to play a scratched disc on xbox 360 or some other consoles
Note: I have only experienced using this trick on the XBox 360 Console.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
on Jan 23, 2010 | Video Game Consoles & Games
I have a 320gb hard drive for my Xbox and when it is inserted it doesn't show on the dashboard for memory devises
In this process your hard drive will be formatted, so back up all files to another hard drive, laptop, or be prepared to lose everything on your hard drive. After you have backed everything up, plug your hard drive into an Xbox 360 then go 'My Xbox/System Settings/Memory.Select 'USB Storage Device/Configure Now' then accept the warning.After the formatting is complete a Performance Warning box will appear, click 'OK.' Now in the 'Storage Devices' screen you should see a new option 'Memory Unit.' This shows that the formatting was successful. Disconnect your hard drive, then connect it to your laptop, load on some media (makes sure the file types are compatible), then reconnect it to your Xbox 360. Your selected media should not appear under 'Portable Device' in the Video/Music/Picture Library.
Dec 27, 2013 | Microsoft Open Box Xbox 360 320gb Hard...
Dear Sir/Madam i want my samsung hdd warranty chek M/N: HD161HJ S/N : SOV3J9BPB69499 TRICK TRICK SOUND HEARING IN HDD
The spinning mechanism is failing. If you can access it from the computer, back up your data as soon as possible. Then, take it to the vendor to claim warranty replacement.
Feb 26, 2011 | Samsung Spinpoint M7 HM161HI 160GB 8MB...
Need to format without losing saved data
The trick to not losing saved data is to back it up to somewhere else, like an external hard drive.
Nov 07, 2009 | LaCie 160GB USB 2.0, 7200 RPM, 160GB...
I HAD A PRO CONSOLE, AFTER ABOUT 3 YEARS IT DIED. SO I GOT A NEW ARCADE CONSOLE & PUT MY OLD HARD DRIVE ON IT. BUT NOW SOME GAMES FREEZE OR WONT LET ME JOIN MY FRIENDS ONLINE MOST OF THE TIME. CAN AN...
try the clearcache trick used to wipe only the basic memory from the HDD this may do the trick,
Go to the system blade and then select memory.
Press Y on the HD symbol and then press X,X,Left Bumper, Right Bumper, X,X. Once you do this a messsage will appear saying: Do you want to perform maintenance on your Xbox 360 storage devices?
Nov 04, 2009 | Microsoft Xbox 360 Console
Lower right hand red light flashing
  1. Turn off your console, disconnect and reconnect all cables, and then turn on your console.
  2. If an Xbox Hard Drive is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
  3. If an Xbox Memory Unit (MU) is plugged in to your console, turn off your console, and then remove the Memory Unit. Turn on your console again, and test for the error. If the error does not reoccur, turn off your console and reinsert the MU. Run alternate tests by having the MU connected and disconnected to see whether the error occurs only when the MU is connected.
  4. If this problem continues to occur, contact Xbox Customer Service. Note If the agent cannot help you resolve this problem, you must return your console to Microsoft for repair.
Aug 04, 2009 | Microsoft Xbox 360 Console
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
How to recover data from a LaCie Porsche 160 GB Hard Drive that's not working?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 02, 2008 | LaCie Porsche Mobile 160GB HD 160 GB Hard...
Microsoft Xbox Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
