I have a Jet Audio 600W car Amplifier and everything is wired up proper etc. But the power keeps coming and going off every few minutes and the flow of power is not constant.
hows the amp wired from the load of your subs? 2 ohm 4 ohm ect. if the load is too low the amp will shut down and cool off then com eback on, thermal overload protection. if your amps bridged at a 2 ohm load, it more than likely cant handle it so run it stereo mode,
my amp keeps going into power saving mode it gets 12v at the power cable and also gets an earth when...
(More)
my amp keeps going into power saving mode it gets 12v at the power cable and also gets an earth when the fuse is out but when the fuse is in it only gets 6-7v which indicates to me that the amp is faulty but i have tried 3 different amps and have had the same problem is the anything else would cause this many thanks
with my car off, power, remote, and ground hooked up(a for SURE good ground) i get 12.6...
(More)
with my car off, power, remote, and ground hooked up(a for SURE good ground) i get 12.6 volts...normal....but once i flip my keys forward (or backward) the voltage goes down to 3.5 ............ ive tried what seems like everything ive put an ENTIRELY different system in, wires and all, to see if it was any of my stuff doing it......i would love to have a working system one day lol...help greatly appriciated
