Question about HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175v all in one
I have a problem with me printer, I m trying to print but I have a message saying open door clear carriage jam, and press enter I already unplug it, turn it off, but nothing is working can you help me with this?
thanks
    Genius:
  • 1,003 Answers
RAISE COVER LOOK FOR big silver bar that ink cartridges ride on apply 2 or three drops of 3 in 1 oil to the top of this bar and then try to print
Posted on Jan 17, 2008
I have a HP psc 2175v printer and it says i have a carriage jam. There is no paper in the printer all at this point and the ink carriage moves back and forth fine, the ink was removed adn replaced but...
The cartridges might not be moving back to there rest stop correctly, check the sponge to the far right Also The clear plastic strip running behind the carriage could be damaged or dirty. this strip tells the printer where the carriage is and if it can not read it, it will cause that message.
Hope this helps
Regards GM
Apr 09, 2011 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2355 try to print a document and receive an error "Print cartridge carriage is stalled " "Open door, clear carriage jam, and then press OK to continue." I tried this and there is...
This can be said as a bit complicated problem. This problem is exhibited by the printer when the cartridge carriage mechanism is getting stuck at some end. I should advice that you make sure that the SS ( Service Station ) of the printer is not jammed / clogged. If yes, try cleaning it. It is also caused when the motor is malfunctions and tries to move the carriage beyond the path that it should go.
It is best recommended that you consult an authorized HP Service person for the solution of this issue.
Thank you.
Mar 06, 2011 | HP PSC 2355 All-In-One InkJet Printer
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
HP PSC 2210 has the error message 'Open Door, Clear Carriage Jam, and then Press Enter'. No paper jams present?
Check door for paper stuck in front of sensor. There is a door in the back look to see if paper shred is in there infront of the back door sensor.
Jul 27, 2010 | HP PSC 2210 All-In-One InkJet Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Carriage jammed
first open the door and ckeck out any optical in carrage moving area are not shigted if the carrage movoing area are free then ckeck in service station it is working properly or not if it is working properly then ckeck the endcoder strip and if it is also ok then reinstalled the mecanism your problem will be solved
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
436 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
