Question about Whirlpool Duet GHW9150P Front Load Washer
F02 code A code is given F 02. The washer is not working. What's up with the machine?
  • gotomeetin Jan 04, 2008
    The same happens with mine. So far, I have just been pushing cancel twice, then switching to rinse/spin, and that usually takes care of it...But if there's anything else causing the problem beside too much soap, i should like to know about it before I wreck my machine...
  • 283 Answers
F 02 means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed. Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Jan 03, 2008
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Oct 24, 2009 | Kenmore Elite HE5t Washer
Hoover ultima code F-02 flashing
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jul 17, 2009 | Washing Machines
Get error code f02
Long Drain
to resolve
  • If the above does not correct the problem, replace the pump.
Mar 02, 2009 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Error code f02
the f 02 means you have a long drain issue press pause/cancel twice to clear the display check drain hose make sure it isnt plugged or kinked check electrical connections at the pump make sure the pump is running check drain filter for foreign objects if the above does not correct the problem replace the pump
Mar 25, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
256 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
