Question about Canon C130F Black and White Copier
Actually a Canon PC-65, problem follow-up
I Thank you for your prompt response. On further testing with your suggestions I have noted that the toner buildup appears to be on the cartridge drum. The plate, lenses and paper paths all appear functioning well and tested out. I should reiterate that the model of copier I am working with is a Canon PC-65 (an older small personal copier) which I could not find on your web site. The toner cartridge is an A-30-L black. I think what I need to understand is the principle that is in play that attracts the toner to the drum as this appears to be what is malfunctioning. When copying, the original will copy and the large central smudge line appears to overlay the text copy.
Thanks again.
PSCX
Canon older model PC_6RE problem: the third copy and byond, streeks appear on the left side, progreesivly get worse on each additional copy, a wait of about 2,hours, then the 1st copy is clear again, any solution for this?
Posted on Mar 19, 2008
El problema es que una fuente de luz incide en el tambor fotosensible o este es expuesto a luz fuerte, por eso aparecen manchas, se debe manipular en lugar obscuro y/o buscar la fuente de luz indebida dentro de la maquina, despues de unas horas de reposo dentro de la maquina se restablece la impresion normal.
Posted on Sep 29, 2008
  • 62 Answers
The canon PC 65 and the Canon PC 11/12 . If the cartridge is printing with a black smudge, then check the cleaning blade located inside the toner cartridge.
It the drum is cleaning, then check the fuser roller at the exit of the machine.
There is also a place u can get parts for these as well and thier parts is real cheap.
Posted on Jan 04, 2008
How to reset inkje even with new refilled cartridge
Regarding your recent inquiry about the Canon 240 (black) or 241 (color) ink cartridge ink alert/error condition and the inability to print to your Canon MX452 printer, to reset the cartridge ink low/empty alert message condition, depending on your printer model, we suggest you follow the documented procedures below and/or provided on Inkjet411 at the following link. http://inkjet411.com/?page_id=1765
Essentially, in most cases, all you need to do is press the 'Stop/Reset' button (triangle symbol inside of a circle) for 5-8 seconds and the ink error ("ink has run out", etc.) indicators should extinguish; two common reset procedures are provided below (please refer to both videos): http://inkjet411.com/?page_id=1765
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2709
Canon 50/51 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2719
Canon 210/210XL/211/211XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2728
Canon 240/240XL/240XXL/241/241XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2733
Canon 245/245XL/246/246XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2740
If you have already attempted the 5-8 second printer reset without success, then refer to WORST CASE SCENARIO section below.
ADDITIONAL NOTES:
NOTE 1: Providing you can still print, you will need to wait until the "ink has run out" message appears on your computer, before activating the 'Stop/Resume' button for 5-8 seconds. However, if printing is not permissible, then please keep reading....
NOTE 2: If you are able to print the internal self test print, this will demonstrate that the ink cartridge is 'at least' partially functioning. If this is the case, then we suggest you continue printing until the software prompts you to press the 'Stop/Reset' button for >5 seconds. For poor print quality performance issues (as you indicated in your inquiry), we suggest you run a nozzle/cartridge clean test from your Canon software, followed by printing our 'Ink Recovery Test' print: http://inkjet411.com/wp-content/uploads/2013/02/Test-Print_CMYK.pdf
NOTE: To rule out connectivity issues, please ensure BOTH carriage/flex cables (point where the cartridge connects to carriage inside the printer) and BOTH ink cartridge rear electrical contact surfaces are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
      WORST CASE SCENARIO - INTERNAL ELECTRICAL FAILURE OF INK CARTRIDGE:
      If, after performing the suggested 'reset' procedures above, you still have an error condition which prohibits computer/host based printing (or permit copy/scan functions), then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
      If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
      CAUTION: Be advised, the use of Canon compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations which may contain volatile organic compounds, or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
      Canon 30/31 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=3khyqBHMPVc
      Canon 240/241 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=HyEhCOxvdsA
      If you do need to purchase a new ink cartridge (to save on ink costs), we suggest you try a USA remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and come with a 1-year warranty.
      Alternatively, if you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
      Please let us know if you have any questions regarding the technical information provided above by sending an e-mail to us directly: Inkjet411help@gmail.com
      -Thank you
Jul 20, 2014 | Canon Pixma MX452 Wlse All-In-One Printer...
Canon LBP 5300 color problem
You seem to have done all the obvious things. Time to get in touch with Canon Support I think!
http://www.canon-europe.com/Support/
Jan 28, 2014 | Canon LBP5300
My Canon MF3240 Printer says "Toner is not set" "Insert Toner". I've tried all the stuff I found online such as... - remove paper, remove and replace toner - clear paper or dust...
Welcome to Fixya
This means that the toner is inserted properly. I provided you link on how to install the cartridge properly. Try to take out the cartridge and wait for 1 minute then put it back in.
Let me know if you have further questions.
Thank you for using Fixya!
Apr 08, 2011 | Office Equipment & Supplies
The toner light has been flashing. I have now put in a new toner cartridge and my amber light is still blinking
Please reset the pc count on your printer. Please click on the link below for the steps. http://bitly.com/r8ZhYJ
If you need further assistance, please contact Lexmark Technical Support Center.
Mar 30, 2011 | Lexmark E260 Laser Printer
What to do if the windows operating system is not responding? how to reformat an acer aspire one netbook?
Select models have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: Ensure that all important data is backed up as restoring your system will restore it to the factory default specifications, resulting in lost of any user data which has beeen added or modified.
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Acer Aspire ONE 532h2727 Atom N450 166 GHz...
I cant find the mac adress of the laptop to add it to my wireless network so it is not getting a response from my network modem
To find the mac address of your computer, follow these steps....
1. Go to the start button.
2. Type in "cmd" (without the asterisks)
3. Type in the command prompt, "ipconfig" (without the asterisks)
4. The Mac address should be displayed in the command prompt.
Aug 21, 2010 | Dell Studio 1737 Laptop
Streaking copies
Have you changed the drum unit recently or emptied out the waste toner in the drum unit? If not try to empty the waste toner and clean the area that is right under the drum unit... * Note* do not wear any thing white... Toner can make a vey big mess...
Jan 26, 2009 | Office Equipment & Supplies
No install cd for canon canoscan 3200f
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Canon Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find thefile,doubleclick on the file, if you get introubles,then follow the instructions below to reset and reinstall:
  • Unplug USB.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some device does not work on Vista
Oct 12, 2008 | Canon Office Equipment & Supplies
Black text or black print is faded in a 2" vide area
Although the drum life is at 65% it could still have a problem. It could be that the end of the drum is starved of toner or there is lumpy toner in the drum. Take out the black drum and give it a good shake then a gentle one to level the toner out and refit. Had the same with a canon unit 2 weeks ago. If still no good then a new drum is required. I bet you are using recycled drums!!
Sep 23, 2017 | OKI C5200n Laser Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon C130F Black and White Copier Logo
595 people viewed this question
old marine
old marine
