Dell Dimension 4600 PC Desktop
Problem for Dell Dimension 4600 PC Desktop
I have a computer that was given to me, however I
By tucksharon2 on Nov 03, 2009
I have a computer that was given to me, however I cannot login to Windows XP because the previous owner moved out of town. I need there sign on or reload windows. There isn't an option for a guest sign in. Please Help!
Clarification Request
Posted by jaye_ellen on Nov 03, 2009
Did you get any disk with this computer, so you might be able to reload XP? And other driver software needed to use the computer? Can you perhaps get a new Operating System to install?
Solution #1
posted on Nov 03, 2009
Not Rated)
mijamhel
Rank: Guru
Rating: 85%, 20 votes
Hi, in order to sign in to your pc you have to download some hacking program but this will take long, I'll suggest you format your hard disk so you can use it without the hassle of spending some time looking for the software. Goodluck and hope it help.
Was this helpful?
Yes
No
Solution #2
Not Rated)
proton77
Rank: Wiz  Dell Computer Hardware  Expert
Rating: 84%, 406 votes
You can try the following, Restart the computer and Press the F8 key a couple of times on the Dell splash screen before windows loads .
Select the option Safe mode and hit enter , hit enter again on the next screen.Once the screen loads select the admin account to login.
If you are able to login to the admin account , click start >control panel >user account and there you can reset the password for the previou owner.
If this doesnot work , you would have re-install windows , using the Dell restore disk. Use the following link for the same
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?docid=347576
Thanks for using Fixya
Proton
Was this helpful?
Yes
No
Solution #3
Not Rated)
Dageezer
Rank: Guru  Dell Computer Hardware  Expert
Rating: 89%, 967 votes
You'll need either a 3rd party application like ERD Commander or a clean reinstall of Windows.
Here is one link, personally I haven't tested it though.
http://www.petri.co.il/forgot_administrator_password.htm
Was this helpful?
Yes
No
Solution #4
Not Rated)
TheSelkie
Rank: Guide  Computer Hardware  Expert
Rating: 0%, 0 votes
http://www.mydigitallife.info/2006/11/25/easily-login-to-windows-xp-with-no-password-administrator-account-backdoor-trick/
Go to this link to get started. If you can't login as Administrator with no password, you'll have to get the crack programs or reinstall windows.
Good Luck
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4600 PC Desktop
Questions and Unsolved Problems for Dell Dimension 4600 PC Desktop
Do you recommend Dell Dimension 4600 PC Desktop?
Answer
Answer
which intel motherboard ( model detatil) is suitable for an intel dual core 2.6 Ghz processor?also... (More)
Answer
Drivers for nikkai usb 2.0 tosata and ide adaptor
Answer
hopw to programme vat for the XE-A41s
Answer
my lap top web cam is upside down how can i bring normal? help me .
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
