I have a GE Washing Machine WBSE3120B1WW that is making a loud ''clicking'' noise during Spin phase. When there is less water there is no noise. I have the front panel off and can not determine where exactly the noise is coming from. The belt is moving, the transmission is moving intermittently during the spin phase. Need some help before I spend money on a part I may not need. Thanks.
Clicking noises are most often associated with bra wires , sticking in between the drums , have a good look all around the inner tub with a torch if you spot a wire sticking through carefully pull it out with pliers but dont loose it , once it goes all the way through it is neccesery to completely dismantle tub assy to remove it.
Was this helpful?
Yes
No
Popular Solutions for GE WBSE3120B Top Load Washer
GE Washing Machine WBSE3120B1WW -when I first start the washing cycle you will start to hear a loud...
(More)
GE Washing Machine WBSE3120B1WW -when I first start the washing cycle you will start to hear a loud clucking noise and the motion of the tub becomes very slow and then it stops all togehter this will repeat untile the wash is complete can you help diagnose?
how do i remove relay from ge washer it has slots on each side and does not want to come it seem...
(More)
how do i remove relay from ge washer it has slots on each side and does not want to come it seem like it will break
Our top loading washing machine in condo near the ocean has a loud grinding sound -- like sand has...
(More)
Our top loading washing machine in condo near the ocean has a loud grinding sound -- like sand has gotten into the gears (parts of the motor mechanism. Lots of tenants use our condo during the summer. Solution?
http://www.flickr.com/photos/17447564@N03/with/4016949524/ I'm trying to replace the tub hub. It is...
(More)
http://www.flickr.com/photos/17447564@N03/with/4016949524/ I'm trying to replace the tub hub. It is broke to many pieces. I have chiseled off the hub nut because it would not turn at all. But now I cannot get the center part of the hub out of the washer (see pictures in link above). I even tried a gear puller since the hub is broke from the tub I was able to use the gear puller but did not work. The gear puller actually bent :-( How can I get the rest of the hub off?
