Question about Pioneer KEH-1800 Cassette Player
  • 132 Answers
Depends on the kind of car, if there is a "CAN" around it then there is a metal cahe that you need to slide 2-4 removal tools in the sides to remove it, you can use any think metal tabs abought 3-4 in long as removal tools,
if its an ISO DIN mount there are screws holding it in from the sides.
if this doesnt help much can you tell me the make and model of the car?
Posted on Jan 03, 2008
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
DIY Mazda Car Radio and Speaker Removal, How to Remove
'96-99* Car Stereo Removal · Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
Jan 31, 2016 | Mazda Cars & Trucks
I have a pioneer keh-p5400
You are not going to be able to find a new radio that will run a changer.
Nov 10, 2011 | Pioneer KEH-P5400 CD Changer
Remove dash on 2002 chevy tracker and remove factory stereo and install new one
Glad I didn't read this page before I replaced my stereo.
Remove stereo fascia with three screws - 1 at the top, two on each side of ash tray. Remove 4 screws holding in stereo. Done - takes about 3 minutes.
Oct 29, 2011 | 2002 Chevrolet Tracker
How to remove the CD player from dash
you must remove the dash panel that goes over the stereo, heater and around the gauges then all you have to do is pull it out just by pressing two tabs on each side of the stereo
Sep 11, 2011 | 1998 GMC Sierra
How does the cd player stereo come out?
Remove the two end panels on the dash. These are the panels that are located on either end of the dashboard. Place a rag over the tip of a flat tip screwdriver and wedge the tip behind the panel. Then pry the end panel off the dash. Do this for both panels.Remove the nine screws holding the glove box in place. Remove the two screws under the side panel on the passenger side (removed in step 1), four inside the glove box, two under the glove box, and one in the bottom left corner of the glove box (you can only access it after removing all of the other screws and extending the glove box down beyond what is normally allowed with the other screws in). Remove the screws holding the dash on under the steering wheel. Remove the two under the panel on the driver's side panel (removed in step 1), three on the underside of the dash, one on either side of the steering column, and one near the bezel covering the stereo.Pull the dash off from around the stereo controls.Remove the clip and wiring for the hazard switch using a flat tip screwdriver.Remove the six screws holding the HVAC unit and stereo unit in place and pull the stereo straight out of the dash. Unplug the electrical connection from the back of the stereo.
Jan 10, 2011 | 2006 Pontiac G6
How to remove and put the a new radio in a toyota highlander 2002
  • Disconnect the negative battery cable and ensure it doesn't contact any metal parts. Place the transmission into the "Drive" position and set the parking brake.
  • 2
    Remove the trim from around the stereo by prying at one of the bottom corners with your fingers. Apply pressure until the clips disengage and work your way up the trim. Once the trim is free from the dash set it safely aside.
  • 3
    Locate and remove the six 10mm bolts that hold the stereo in place. Pull the head unit out of the Toyota highlander dash and disconnect the wires from the back of the radio.
  • 4
    Connect the wiring harness adaptor to the original harness. Mount the new stereo into the Toyota radio mounting kit and secure it by following the manufacturer's instructions. Plug the wiring harness adaptor and antenna wire into the back of the new stereo.
  • 5
    Slide the entire stereo assembly into the dash and reconnect the battery cable. Turn the radio on and verify the speakers and controls are working on the new stereo. Secure the stereo in the dash with the six 10mm bolts and replace the trim ring around the radio.
  • Dec 07, 2010 | 2003 Toyota Highlander
    I Loss The Face Plate
    Remove the stereo and check the model and serial number in the back
    and check
    and they might let you know if they have it available and the cost
    have a nice day
    Dec 06, 2010 | Pioneer KEH-P1010 Cassette Player
    How do i take out my radio from my toyota corrola
    The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
    Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
      > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
      > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
      To install
      > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
      >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
      > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
    Dec 05, 2010 | 1990 Toyota Corolla
    try pressing the reset switch or disconnect power to the radio for a few minutes.
    Aug 19, 2010 | Pioneer KEH-P1010 Cassette Player
    Pioneer KEH-1800 Cassette Player Logo
    161 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
