Question about Pioneer VSX-54TX Receiver
Cracking and poping with Yamaha surround sound system
I have a Yamaha system with a receiver and 5 speakers hooked up to digital cable, DVD player and a VCR. The system has been working perfectly for the past 3 years. I turned it on today to watch TV and after about 30 minutes it started to make an awful cracking and poping noise in all of the speakers. Kind of like static, but louder and more annoying. The noise does not go away when I change the TV channels, but it does go away when I play DVDs. When I play DVDs it is like it used to be with no popping noises at all. Can you help? Also, don't know if it is important, but there was a power outage at my home over the weekend. What can I try? This is unit - Pioneer VSX-54TX 7.1 Channels Receiver - is only a year old - the odd time there is a popping or knocking sound coming from the rear speakers - recently this sound has been present in the front main speakers after I turn off the unit - this noise only stops when I turned off the power to the Anthem 2 channel amp (used on the two main front speakers). Thanks. integra 7.2 receiver / onkyo has the same problem with a cracking noise that moves around from speaker to speaker, likely in the processor board. I am going to try using this for just two channel and see if it happens.
  • Pioneer Master
  • 924 Answers
If it only pops and ticks on certain inputs, you have a damaged Input Switching IC, as that is the only part that selects from one input to another. This IC is controlled by the Display Microprocessor(one of the computers in your receiver). There may even be a poor ground to the board that IC is on. Do not try yo reground the receiver as mentioned above, That may well lead to certain fatal harm to yourself! If you'd like more information, please refer to my website, audioserviceclinic.com, where you'll find 2 seminars that I wrote for Pioneer. I worked there for 6+ years. 40 years in the industry in total.
The good news is that Pioneer has a warranty for two years. Bad news, is that Pioneer home products has been sold off about two moths ago, to some Asian consortium 75%, and 25% to Onkyo. They are still taking in products through their authorized service centers, but I already know that many parts are no longer available. This will result in the replacing of your unit, most likely, a Grade B(refurbished product) rather than a Grade A(brand new receiver, which I seriously doubt is available anymore). Good luck, in whatever the outcome. I can certainly repair your unit on an out of warranty basis(see website above)
Posted on Nov 26, 2014
    Genius:
  • 1,226 Answers
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Posted on Jan 04, 2008
6ya staff
SOURCE:
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
Mar 09, 2011 | Yamaha RX-V793
No sound from rear speakers with TV and DVD player
You also have to connect a SPDIF coax or optical from both the DVD player and from the STBox into the digital inputs on the rear of the receiver. And select them with the remote control.
Apr 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Nne help hooking up speakers to entertainment system
If you have a optical out on your dvd player and optical in on the receiver that is the best connection for digital sound, the vcr section will have to be hooked up analog using rca cords
May 26, 2009 | Mintek LCD TV Progressive Scan DVD Player
I CANNOT GET MY OLDER VCR TO WORK WITH NEWER EQUIPMENT.
The VCR is straight analog/composite and if you are trying to get it to show up on the TV via the HDMI connection between the receiver and the TV it is probably not going to work correctly until you add a dedicated pair of audio connection from the receiver to the TV...
Mar 16, 2009 | Jensen JW250 Main / Stereo Speaker
Hook up Cox Dig CBL Box to receiver and TV for home theater
The easiest way to proceed is by using RCA cables (the red, white, yellow) to connect the cable box.
Jan 02, 2009 | Pioneer HTD-510 System
Yamaha htr5230 hookup
Hi, Your receiver is really the same as my HTR 5240. Same back and front. basically. Go to Retrevo for manual. Shows all the hook ups. I have VCR , DVD, Tape Deck, hooked to mine but can't find the adapter so i can hook up my indoor fm antenna. All my components plug to back of receiver then there is one RCA wire running from receiver to Tv.
Sep 01, 2008 | Yamaha HTR-5230 Receiver
RX-V663
is the dvd layer on bit stream output or digital mode ? cheak dvd players setinsg run red white to sterio video in yello to tv for picture ok or use digital cables ect
Jul 06, 2008 | Yamaha Audio Players & Recorders
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
Pioneer VSX-54TX Receiver Logo
507 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Anthony
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
