Question about Hoover F6055-900 SteamVac Maxextract LS Wet/Dry Vacuum
My Hoover Steamvac Max Extract's "Tank Full" light keeps blinking, even though the recover tank is completely empty and the floater that activates the sensor remains in the down position. The vacuum still has suction in both floor and tool modes, so the vacuum still appears to function. Should I just ignore the light and continue use as usual, or is there a problem that still needs to be addressed. I don't want to blow up the motor.
Thank you!
  • MongoK Oct 24, 2008
    Mine also blinks with the check valve all the way down.
    President:
  • 1,673 Answers
Might just be a bad sensor, or it is coated over with dirt. If the tank lid has one of those round filters on it, make sure it isn't pushed all of the way up to the top, needs to have a 1/4 inch gap.
Posted on Jan 06, 2008
Automatic shut off comes on as soon as I start cleaning the carpet
Try taking tank out see if the sensor that might be stuck or the tank may have a small piece broken off that keeps the auto shut off working. Try utube for further videos on this problem.
Sep 22, 2016 | Hoover SteamVac Spinscrub 50 Carpet...
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Www.hoover.com
Having never used a steamvac I can only only offer this....pump
and nozzles dispense solution....Is the pump on and working?
Are the nozzles clear? This is all I have...hope it helps.
Regards,
Dennis
Aug 18, 2014 | Hoover F6055-900 SteamVac Maxextract LS...
My max extract 77 hoover wont spray
Make sure all water lines are not clogged with anything 1st. Then check to see if the switch/lever or button that actuates the spray is functioning/working. If it's a mechanical switch/lever etc, see if you can take it off and clean it thoroughly and check to make sure there are no broken parts. If it's an electrical switch/button or lever, you need to check and make sure it's clean, and all the contacts to wires are NOT broken or damaged. You may have to replace parts if they don't function.
Oct 15, 2013 | Hoover F6055-900 SteamVac Maxextract LS...
My Hoover SteamVac Max Extract 77's dirty water tank won't fill. The water seems to just filter right back to the floor. What do i do???
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Jan 22, 2011 | Hoover F6055-900 SteamVac Maxextract LS...
The brushes are not working.
We have a Max Extract 60 and when we turned it on the brushes did not work. My husband took the pieces for the brush motor apart and put it back together and then they worked fine. They must of been bound up or put together wrong. Works great now.
Dec 21, 2010 | Hoover F6055-900 SteamVac Maxextract LS...
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
Willl not vacuum up the water
Means the suction is clogged by carpet or other debris take apart and clean as necessary.
Apr 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
Hoover F6055-900 SteamVac Maxextract LS Wet/Dry Vacuum Logo
378 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
