That all depends on what you have your settings for. If you are not using the program mode, you'll need to make sure to check your Aperature and Shutter speed. Adjusting these might make your pictures come out better. Make sure to check your light meter, the needle or indicator should be in the middle for best results.
You may request a free copy of the manual here. You'll have to email the webmaster and specify the Canon Rebel 2K manual. The webmaster also requests a contribution, but that is optional.
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Dirty contact in the battery compartment, bad power circuit, bad switch etc. Too many things to be able to fix in this forum. Send it in for service or buy another used one, that may cost a lot less than getting yours repaired.
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
