Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have just got a new vista laptop and cant get a connection without a lead.
I have tried re-installing the cd installation disk, but it's not getting a connection. I can only get access to the internet via my ethernet lead, any ideas?
  • 556 Answers
Does your laptop have built-in wireless?
If so it has an on/off switch so you can use it in planes. Have you turned it on?
Using the following link for instructions
execute the command (one space before /)
ipconfig /all
Record the following
  • IP Address
  • Subnet Mask ---------(wired should match wireless)
  • Default Gateway ----(wired should match wireless)
  • DNS Address(es) ---(wired should match wireless)
Using the same command window then this command (replace the with the default gateway from ipconfig if different)
this should display 4 messages with elapsed times if it works and 4 timeout messages if it fails.
Once when wired and once when wireless
-- from what you have said the wired answers should be right
------ we are going to compare to wireless to look for problems
-- tell me the differences between the two displays
-- you will need to write down the results from each pass
If the switch issue does not solve the problem the above information should allow me to determine what is wrong.
Posted on Jan 04, 2008
I bought a new hard disk for my vgn-nr120e because the old one was corrupted and im trying to install it but my comp is just displaying an all black screen(it appears to be off) but the led light is on and...
Since you say, you have a new hard disk I am assuming you have not formatted it or there is an operation system on it. If that is the case, power on your laptop. As soon as you does this start pressing F2 (intermittently = press, then release) and keep on doing it till you get into the bios screen. Once you are there change the boot sequence to CD drive first (It will be on Harddisk at present) Once you have made the first boot device to CD drive, open the CD drive and put an operating system CD like XP, Vista or Windows 7. Save and exit from the bios screen. Restart the computer. It will say press any key to boot from CD drive. Press any key. The system will come to the operating system installation screen. Install the operating system. If in doubt get assistance in getting someone to install the operating system. Without the operating sytem or a bootable CD once the Bios hands it over to the system there is nothing to display and you do not see anything on the screen. It looks like that is your problem. Good luck.
Feb 08, 2010 | Sony VAIO VGN-NR120E/S Notebook
How do I install windows XP on Compaq CQ40 327TU laptop
Try downloading Hiren Boot CD and run you can resize the Harddisk accordingly.
Mar 31, 2009 | Computers & Internet
Copy windows vista from my laptop to my acer pc
you can not just copy vista. you would need to get an install cd of vista and install it onto the pc. this still may not fix your internet problem as there is no guarantee that vista will even have the drivers for your pc components.
Mar 10, 2009 | Acer Veriton 7600G PC Desktop
Replace a cd/dvd drive on my Laptop
Not possible at all. To install XP or Vista again, you need a CD/DVD drive working. (or) Contact Aspire(or local technician) if they can ship a XP/Vista pre-installed Hard-disk.
Jan 12, 2009 | Acer Aspire 3000 Notebook
Hard disk not found on Dell
actually you cant install operating system. first u have to install lower version and then install higher version of os. install original operating system dont use pirated version
Jan 08, 2009 | Computers & Internet
Xp on a vista laptop
I regret to inform you that it is not possible to install XP in the HP or Compaq Notebooks which are shipped with the Vista Operating System. To install XP in your notebook, you need to disable SATA option from the BIOS . I am afraid that there is no SATA disable option the BIOS. Hence, it is not possible to install XP in the notebook.
I understand some of the softwares are not compatible with Vista operating system. But, if you insall Vista SP1 in your notebook. You can also use the software which were not compatible with Vista, after installing Vista SP1.
Jun 25, 2008 | Compaq Computers & Internet
Help me connect printer to laptop
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
May 10, 2008 | Lexmark X3350 All-In-One InkJet Printer
Install printer to laptop
Jan 18, 2008 | Acer Aspire 3050-1733 Notebook
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
76 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
