Question about Panasonic AG-EZ30 Mini DV Digital Camcorder
Output from breakout box is distorted
Camera displays correct video on its LCD display on playback but video is blue green on TV via RCA plugs and s-video
5 Suggested Answers
SOURCE: LCD no image
it is same with my camera same type also.the problem is from flexible cable from mainboard to lcd .same of the core is break..until now i can'ot get that cable.
you just buy the cable and on your camera and ok.
if you have information abaut that cable please submit to me
Posted on Oct 22, 2007
SOURCE: Problems with Playback and No Sound..
Had some problem! Hitting it worked great. I don't know for how long, but it is working now! Thanks for the barbaric solution! Woohoo!
Posted on Nov 18, 2007
SOURCE: Camera Will Not Play Back Video!!
normally you receive a head cleaning tape with the unit or you should purchase one and let it run untill it stops playing. i suggest you run it 2-3 times if this does not solve the problem then you may need a head chage. the change will have to be done by a qualified technician.
Posted on Jun 25, 2008
  • 544 Answers
SOURCE: blue lines appear across screen during video playback.
thank you for choosing
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
please don't forget to rate our answers properly.
Posted on Mar 03, 2009
SOURCE: Panasonic SDR-H40-Date/time missing when transfering video to PC
get a capture card, an AV cord ( red, yellow and white cord) and record it onto the computer. This will push the date and time stamp onto the video. There really isnt any other quick solution :-(, unless you sport 800$ for a highend camera, then all harddrive cameras have this problem.
Posted on Mar 18, 2009
0 characters
1 Points
Camera switching on ok but lcd sceen blank
Your problem can be the result of a number of causes - two common ones I will list here.
Most common cause would be a failed printed connecting cable between the main camera electronics and the flip out display panel. This special cable passes through the display hinge and is sometimes subject to failure.
A second possibility is a faulty display backlight.
You can check that the camera is still producing video output by using the AV cables conected to a TV display with the camera set to CAMERA mode.
I trust that this information is of assistance. RHN
Jan 02, 2010 | Sony Video Cameras
Blue screen when using VCR function
Hi and welcome to FixYa,
A blue screen is 'video muting', the player is not getting a decent video signal and rather than display distorted / noisy video, it is muted.  Initially, has a video head cleaner been tried on the camcorder?
Good luck and thank you for asking FixYa.
Aug 02, 2009 | Sony Handycam DCR-TRV80 Mini DV Digital...
When I plug in my camcorder to the tv using the AV cable and select the correct tv input, the picture does not display on the tv and there is a trememdous amount of feedback.
I connect my camcorder to the TV with regular RCA plugs (yellow, white, red). The camera RCA plug-in holes are in a separate compartment. I can see what I am recording on the TV if the camera power switch is pushed over to "camera". I do my recording. Rewind. Then I have to push the power switch to "off" then over to "VCR" , and push "play" on the camera in order to see the play back on the TV screen. See if your power switch has several positions. I hope this info. is helpful.
May 17, 2009 | JVC Everio GZ-MG335 HDD Camcorder
Downloading problems - distortion???
I have my pc hooked up to my hdtv via vga cable and the video playback is as good as it is if i were to playback from camera through hdmi ,my screen resolution is 1360x768 which is slightly higher than standard hd but lower than full hd but honestly I doubt you could tell the if you have a graphics card that supports 1920x1080p and obviously the tv also, you dont need hdmi out on pc......vga cable does the same job! im running an nvidia 8800gtx
Aug 23, 2008 | JVC Everio GZ-HD7 Camcorder
Recording. How to disable onscreen icons diplaying on record?
Go to camera Manu and check Display properties. There you will find display option on LCD or Video Output. select it Display On LCD.
Jul 29, 2008 | JVC GZ-MG130U Camcorder
Color balance of video output
an estimate of repair is pointless it would cost less just to get a new camera.
Jun 26, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Bad colors on Swivel LCD Display
it is more than likely the flex in the hinge for the lcd. the hinge might need changing. suggest the camera be taken to a qualified panasonic tech.
May 31, 2008 | Panasonic PV-DV103 Mini DV Digital...
try cleaning cassette or the head needs aligned
Jan 27, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Black and white playback on television screne
Select the correct color system in your tv. probably the system which was selected in your tv did not match that of your video cam. good luck!
Feb 15, 2007 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Panasonic AG-EZ30 Mini DV Digital Camcorder Logo
18 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
