Back to:
Tags:
RCA D52W19 52 in. Rear Projection Television
RCA D52W19
posted by NolanLong on Jan 03, 2008
I have never worked on this model before? when i push power set makes a high pitched noise 3 times and does not power up there is no click from the flyback? Unit has the ITC222,made in 2003 customer said they were watching it the set made a loud snap sound then shut down? I ordered the schematics from Thompson they gave me a hard time about it? whats up with that?said it would take 4-6 weeks to get them if you can help please do? Thank you.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 04, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sorry i did not notice this set has a (B) at the end D52W19B
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on RCA D52W19:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rating: 0%, 0 votes
Does anyone know the part # for the flyback and horizontal out puts?
Thank You!
Solution #3
Not Rated (0)
Guest
Rating: 0%, 0 votes
TY all from what i am reading this set has some major problems? lol RCA at its finest lol
Thank You!
Solution #4
posted on Jan 03, 2008
Not Rated (0)
troylove11
Rank:Wiz Wiz
Rating: 84%, 1094 votes
Could be flyback, but there are alot of checks you will need to do like Data and Clock and IP551 for +1.8 volts stand by , and so on and so forth. You will need that schematic.
Thank You!
Solution #5
Not Rated (0)
BMW Rider
Rank:Guru Guru
Rating: 91%, 252 votes
Nolan, heres the part number for the service manual on paper,
"PITC222" dealer cost is $54.95 at Tritronics, they show 3 in stock, souinds like you`ve got a bad flyback, hope this helps BMW Rider
Thank You!
Solution #6
Not Rated (0)
willtab
Rank:Guru Guru
Rating: 89%, 404 votes
There are two flat ribbion cables betwwen the deflection and signal board when you hear that sound the first thing to check is those cables make sure there seated first
Thank You!
Can you Help with these Projection Televisions problems?
RCA D52W19 52 in. Rear Projection...
when watching the screen seem to be zoom in to much
Tosiba 52" dlp won't stay on?
Problem first started out having purple shots in the...
I have a RCA 51 screen tv, the picture is good just cloudy
when i turn my tv on theres just a blue screen with a few...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
