Question about RCA RCR460 Remote Control
Rcr460 yes please. i need a 4 digit code to work with rca universal remote, model rcr460, for my toshiba tv. and thank you.
  • Anonymous May 27, 2008
    I had the same propblem and the solution that you gave for this person worked excellent for me. Thanks !!!!
    Problem Solver:
  • 3 Answers
Hold the tv button down and type in one of these codes, after entering the code try to change the channel...if it doesnt start over......Toshiba Tv codes - 1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241
Posted on Mar 13, 2008
  • 579 Answers
Here is the site for remote codes:
www.remotecodelist.com/remotes/
Hope ya fix it!
Posted on Jan 03, 2008
2 Suggested Answers
SOURCE: i need a 4 digit code to work with rca universal remo
how do i program to a zenith
Posted on Mar 31, 2010
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
NEED TO GET RCA UNIVERAL CODE FOR RCU704MSP2N T0 G0 TO A SHARP MODEL 13F/M50
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 25, 2010 | RCA Universal Remote Control
RCR460 Remote Control: I need to know how to program my rcr 461 to my tv....
Please follow the below steps to set up your programme
Direct Code Entry:
  1. Find the code your device.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Enter the 3-digit code number.
  5. Release "CODE SEARCH".
  6. With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5.
Code Search:
  1. Turn on the device you wish to control.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Please
device to be programmed(VCR,TV)
Thanx
May 16, 2010 | RCA RCR460 Remote Control
I need to program an RCA universal remote for a Toshiba TV
Ideally I need the exact model number of the RCA remote you are using as these remotes use different 3 or 4 digit codes.
However I have listed the common codes RCA use for Toshiba. You will need to go through them, one by one, until you hit on the one that works for your particular Toshiba TV.
If for some reason these codes do not work - please post up the exact model number of the RCA remote and I will look at it again for you.
1) Common 4 digit codes for Toshiba
1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241.
2) Common 3 digit codes for Toshiba
000, 048, 049, 071, 072, 073, 105, 109, 117, 118, 160, 161, 162, 190, 201, 207, 283.
Hope this helps. If so a rating is appreciated.
Otherwise please post additional information as requested.
Thanks for using FixYa.
Jan 08, 2010 | RCA Universal Remote Control
Tv codes for a rca universal remote controller
Programminng an RCA remote cotroller for a Toshiba ,CE19H15 model
Jan 25, 2009 | Televison & Video
I need a 4 digit code to work with rca universal remo
1213, 1122, 1123, 1141, 1321, 1434, 1343,
1342, 1123, 1124, 1143, 1114, 1244, 0018,
0019, 0029, 0038, 0047, 0090, 0135, 0174, 0278
Nov 18, 2008 | RCA RCR460 Remote Control
RCR universal remote model# rcr461
I programmed my RCR461 to an Emerson TV by entering code 1170. On the DirecTV, I entered 5059. Found them the hard way, but it works....
Sep 18, 2008 | RCA RCR460 Remote Control
Programing my remote?
you should be able to hold down the desired function you want to program......(for tv, hold tv) since i dont know what tv brand your trying to get it to work with i can only suggest holding down the tv button after you turn on your tv manually and hit the channel up button until it changes the channel. turn of the tv with the remote and see if it turns it back on. if it works you should be good to go. hope this helps
Jan 01, 2008 | RCA RCR460 Remote Control
RCA RCR460 Remote Control Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
