Onkyo A-RV401 amp is not sending any sound to the speakers.
I have a 12 year old Onkyo amplifier(not used that much) that doesnot send sound to the speakers anymore. The owners manual lists an activated circuit protection as one possibility. Can this circuit protection be reset or does this require replacing some electronic part by a service shop familiar with this product? If so the cost may not be worth it. Need your advice!
  • 1,512 Answers
The protection circuit is self resetting, it operates only when there is a fault condition in the amp. there is most probably a failure in the output stages of the amp causing a dc offset condition in the speaker output. The protection cct operates to prevent damage to your speakers. It may be difficult to offer a solution to you for this, it gets a bit complex to fix from here...you may have dry solder joint problems in the output stages, or more likely, failed output components. if you have a transistor checker(ohms meter), then you may be able to determine if any output transistors have failed, I recommend taking the amp to a good HiFi guy for repair. Many (including myself) often replace the all transistors to the last 2 stages when outputs fail. assures reliability in the future to repair this way, but the cost goes up a bit also. expect at least $120 to repair is it is a failed output stage.
Posted on Jan 11, 2008
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
Hi i have bought an onkyo ARV 401 amplifier and i
You can choose any speakers to go with your amp as long as
1) they will allow the amp to perform at its best ( impedance and power handling)
Ideally you will buy speakers which will handle the full amps output plus more, then when you turn it up LOUD, you will not break the speakers
2) you still like the sound when they are demonstrated, installed at your home.
Sound is a very individual thing, if you like it then its fine, after all you are the one listening to it most.
Hope this helps
Thanks for using FixYa
Aug 07, 2010 | Onkyo TX-SR875 Receiver
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
May 24, 2010 | Onkyo M-282 2-Channel Amplifier
Bose 901 speaker with eq
You want them to be your Main Front speakers, right? The news is not good.
There will be some limitations because you can't extract 'processed' L-R from this receiver. The following will give you good stereo and Front L-R from the 901's but it won't allow central volume control or send them any of the DSP effects you may select. Sorry. If it had a Front L-R Pre-Out you'd be good to go for all functions and listening modes.
You'll need a separate stereo amplifier WITH ITS OWN VOLUME CONTROL for the 901's to accommodate the need for the Active EQ. Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
With this receiver we have to cheat to get the Front L-R signal out to the 901's (but it's unprocessed and at a steady volume level)...
For connection I would run a pair of RCA cables from the VCR/DVR Audio Out L-R OUT jacks (*) to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp.
* You'll lose the ability to use these jacks for anything else, but few of us use them anyway. DO NOT select this function for monitoring or you lose all audio in the Onkyo.
Sep 07, 2009 | Bose 901 VI Main / Stereo Speaker
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Dec 18, 2008 | Onkyo M-282 2-Channel Amplifier
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
888 people viewed this question
 Grubhead
Grubhead
