Question about Acer Aspire 3100-1405 Notebook
Aspirre 3100 No key board or mouse control. Acer is no help!
    Sergeant:
  • 239 Answers
Could you explain some more of what you are looking to do. Is it get a key board and mouse working on a laptop, If so when you plug the key board or mouse into the system while the system is on it should recognize the device and install what is needed, If not plug in your items and go into control panel and add hardware button and follow directions. I hope that Help You out If not try a little more info and I will be back to check it out later. Sorry Your having problems and let me know Ok Thanks
Posted on Jan 04, 2008
Touchpad on acer aspire 3100 does not work
and your question is what please? Generally speaking, if there is a mouse plugged in ... the touch pad is disabled.
May 16, 2010 | Computers & Internet
Mouse and keyboard freeze.
its a very common hardware fault with these laptops, can you open setup or bios? that is opened right when the power is turned on the and screen says press F2 to enter bios or setup, if you can't enter bios then you have a faulty motherboard, usb ports don't work either? (usb keyboard and mouse don't work?)
May 13, 2009 | Acer Aspire 3100-1405 Notebook
Cursor stuck in the middle of screen!!!!!
this happened to me. try pressing the Fn key (mine is in blue, next to the left control key on the bottom of the keyboard) and hold it while you press the F7 key and release. try moving your mouse. Those two buttons together turn the touchpad device on and off.
Mar 31, 2009 | Acer Aspire 3100-1405 Notebook
My acer 3100 keyboard and touchpad arent working. any help?
It's possible that something uninstalled the devices from Windows. You can try connecting an external keyboard and mouse, then check the Device Manager to see if it flags any hardware problems.
Another possibility is that the flat cables connecting the keyboard and touchpad to the main board have come loose. To check the cables you need to remove any screws securing the keyboard and pop off the top edge trim to lift the keyboard up.
Mar 31, 2009 | Acer Aspire 3100 Notebook
Mouse pad button is pushed in
start ------ control panl -------- mouse ----------properites-------Buttons--------- Switch primary and secondary buttons ------------apply----------- ok
Feb 10, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
Acer 3500 mouse touchpad totally frozen
have you tried updating the driver
or go to control panel and mouse and check the settings in there
does your laptop work with a normal mouse
Nov 19, 2008 | Acer Aspire 3100-1405 Notebook
Same problem with aspire 3100 wlmi
Hello marpaungroy,
How are you doing? Try the steps below. In 80% of the cases the issue will be resolved.
Here are the steps:
Step 1: As you said you cannot use the key board and mouse there is no way you can go to bios to do bios default. so At the bottom of your laptop you have two compartments. One willbe the RAM compartment and other will be hard drive compartment.
Remove both out of the laptop. Turn on the laptop. wait for 1 minute than turn off the laptop.
Now remove the batter as well and also unplug the AC adapter. press and hold the power button for 1 minute. This will remove static charge.
Now put every thing back. I mean reinser the RAM, HARD DRIVE, AC ADAPTER and BATTERY.
Now turn on the laptop And do a complete PC recoverey using the Recovery CD. I mean do a complete format of the system using the CD.
I am sure in 80% of the cases this should resolve the issue.
If the issue persists than it is a clear sign of hardware malfunction. Mother board needs to be replaced.
Thank you. Best of Luck.
Oct 26, 2008 | Acer Aspire 3100-1405 Notebook
Acer 3100 Notebook Touchpad issues
Dust has built up in and around the touch pad. Purchase a can of pc dust buster, and give it a blast in and around all keys and the touchpad. You may have one sticky key which is causing the pad to behave erratically.
Sep 18, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 3100-1405 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
