If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
how to scan my phone memory afer connecting it to my Pc. Ihave antivirus installed on my computer...
(More)
how to scan my phone memory afer connecting it to my Pc. Ihave antivirus installed on my computer & i want to scan my phone memory.
Nokia model :- 3500c
Connecting via data cable.
Regards,
Jatin
hi mate i need the code to unlock my nokia 6300 from 02 to meteor phone can you please help the imei...
(More)
hi mate i need the code to unlock my nokia 6300 from 02 to meteor phone can you please help the imei number is 356864025532077 thank you so much.
I require the unlock code for Nokia 6300. IMEI is 356777 0245 99204. The phone is locked to Optus...
(More)
I require the unlock code for Nokia 6300. IMEI is 356777 0245 99204. The phone is locked to Optus Australia network. I want to use a Vodafone Australia sim card in it. The other numbers behind the cell phone battery are also below if you require to use them. FCC ID: PPIRM-217 IC: 661U-RM-217 Type: RM-217 MODEL: 6300 Please help in any way you possibly can as the Sim Card is for my work but I cannot use it because the phone is locked. I need this phone to work ASAP. Thankyou very much, Regards George!
The phone crashes on the 188th contact (prev 190th then 189th until I deleted them) and the problem...
(More)
The phone crashes on the 188th contact (prev 190th then 189th until I deleted them) and the problem occurs using blootooth and USB! As it seems, that the problem is not only from 1 specific contact and rather comes from a memory or database problem on the phone, is there a useful solution against it? Also whenI try to update existing contacts details (with additional info) the phone blocks it. It will still allow me to add new contacts though!! Any help will be very very appreciated.
