Sharp EL-1197PIII Calculator
Sharp EL-1197PIII
shared by 2 users
posted by Hammer45 on Jan 03, 2008
My calculator will not print on the paper. It appears that the number roll isn't far enough forward and doesn't rub on the feed roller.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by reesey on Jan 04, 2008
Similiar problem with my TI-5630, except some of the numbers print lightly and some not at all (i.e. 1 , .3 ) Pattern consistent from line to line. Tried replacing the ink pad but that didn't help. Display works ok.
Can you Help with these Calculators problems?
I cleaned my calculator and now none of the key I press...
any way to adjust the paper guides a little closer, just...
I cannot figure out how to load paper in my calculator. ...
How do you set date and time?
Loading problems.
Repair Service
Find Calculator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
