HP Compaq WF1907 Monitor
Compaq wf 1907 monitor speakers--no sound
shared by 7 users
posted by FacialHarry on Jan 03, 2008
Hi, one minute I was watching a video and hearing it from the built in speakers, and then the sound just went out? Any suggestions?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Posted by tfreid on Oct 19, 2008
Volume is so low you can hardly hear it. Everything is hooked up okay but still no change. Is there a fix?
Thanks
Terry
Posted by Guest on Sep 08, 2008
show connection of speaker with monitor and CPU
Posted by Guest on Sep 04, 2008
Have white lines running down monitor screen and no sound from monitor speakers.
Posted by Guest on Aug 15, 2008
Have speaker at bottom of monitor but can't get any sound. What do I do?
Posted by elfadilme on Aug 15, 2008
je fais resturation. installe le mise a jour .j'ai vue le parameters
Best Solution
posted on Feb 12, 2008
Helpful (85)
hammedbhai
Rank:Apprentice Apprentice
Rating: 85%, 8 votes
sol: control panel
check with the properties of sound keep in default....
make sure the volume control is not muted...
run a test on sound on the sound mixer........
reseat the connections and try to play
try to play the sound with other speakers
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on compaq wf 1907 monitor speakers--no sound:
I don't want to Accept this solution
Best Solution
posted on Jan 15, 2008
Helpful (85)
Nspektor
Rank:Wiz Wiz
Rating: 90%, 60 votes
Check output with a known working set of speakers first to determine if the problem is with the computer or monitor built in speakers. If it is the monitor speakers you will need to decide if it is worth opening your monitor to fix it or just using other speakers. Some monitors use internal speakers and utilyze the power supplied to the monitor to amplify the speakers. It will require some skill and the right tools to repair.
Thank You!
Provided by HP STAFF
Solution #3
posted on Feb 26, 2008
Thanks for Trying (70)
gunjansarkar
STAFF
Rank:Wiz Wiz
Rating: 82%, 34 votes
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Thank You!
Can you Help with these Monitors problems?
hello my sound volume is not working? i just got this...
all of a sudden picture quality is dark and cannot see any...
I have been successful connecting my Playstation3 to a...
i have no sound in i tunes and i cant opperate the volume...
when I log into Yahoo the page covers the entire screen...
6 Other Users Have The Same Problem - Continued
Comment by co1ene, posted on Feb 17, 2008
I have a HP 1907 wide screen monitor. There is no volume on the speakers. I can just barely hear them. External speakers work, so it is not the PC. The settings are correct under the control panel.
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
