Our washer stops about 15 minutes into the cycle. The little tube from the drain pump is clogged, but I cleaned the drain pump filter. The washer worked for a couple of days, then reverted back to the old problem. If i restart on a rinse/spin cycle, it seems to run through to the end.
Very important that the thin tube is clog free, disconnect from top to blow into it, clear if any block, refit. This is connected to the pressure switch, controls water level.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Important: height of drain hose is abt 3 feet from ground level.
Rate me pl.....if helped.
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
I am havinga the same problem, but I get a message that says LE
