Question about Panasonic CT-32G19 TV
Tv wont come on had a powersurge hasnt come on since why?
Hadc a bad breaker in my house and the power would go on and off. then it did it when we fixed thebreaker now tv wont come on at all .when you plug it in it has a little spark at the power plug .but wont come on .its only 2 yrs old
    Master:
  • 619 Answers
TV fuse open /replace
If same proiblem fuse pop the power IC was shortage.
Posted on Jan 04, 2008
  • leo2 Jan 04, 2008
    If our power in our hause has always on and off all appliances will be dsamages , make it sure the power is stable and it better you have power back up like use in computer or delay timer gadgets.
I rewired the power cord to my JVC Projection TV, because the old one had been chewed up. Now, when I try to plug it into electrical outlet, it sparks and blows a breaker on my house breaker box?
The wires are shorted together somewhere! Or you switched ground with hot or neutral!
Are you trying to burn down your house?
Even if you manage to get it working, it still could be a fire hazard because it isn't done correctly! Wrong kind of crimp or a bad solder job can create a fire!
PLEASE get someone that knows electrical or electronics to fix it!
Most of the people I know that have the background can fix it correctly in about 10-15 minutes.
Jul 28, 2016 | JVC HD-61Z886 61" Rear Projection HDTV
THE DRYER WONT START,FILTER AND VENTS ARE CLEAR. HOW DO YOU FIX THIS PROBLEM?
Several reasons can cause a no start dryer condition. I'll start with the easy ones first. If a gas dryer, it runs off 120 volts. Check the house fuse or breaker or plug a light into the dryer outlet to make sure you have power. If outlet is OK then we have several dryer problems possible. If the dryer is electric, it run off 220 volts. You need a voltage tester to check the 220 house plug. Could still be a problem with the house 220 breaker. On the dryer itself, the first thing to check is the door switch. If the door switch is bad the dryer will think the door is open even when it is actually closed. Next, some dryers have a switch on the internal belt system. If the belt breaks, the dryer will not run.(only on some newer models). Couls also be a bad timer assembly. Some of these may need a tech to actually test since it requires taking the dryer apart to get to these item.
Feb 28, 2015 | Dryers
How to fix treadmills JKEXER vigor 6090 broke down with smoke and fire ?
sounds like motor went bad tripped the breaker ! go to fuse box look for breaker that's not all the way on turn it off then back on that will get your power back on make sure you un plug treadmill
Sep 06, 2014 | Exercise & Fitness
My nec plasma sync tv wont turn on
Is it plugged in?
Lol gotta ask that.
If so, you might have a problem with a dead power supply or perhaps even the outlet where it's plugged in is having an issue...blew a fuse, tripped a breaker.
First try plugging it in somewhere else (another room).
If that doesn't work, and there is power in your house, you might need to take it to be serviced or toss it and buy a new one.
Nothing lasts forever. You just need to determine if the price of service + parts is worth it.
Aug 17, 2014 | NEC PlasmaSync 60XC10 - 60" plasma panel...
My hdtv visonquest just overheated and wont turn back on how to fix this?
follow this steps and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
Verify you are getting cable/satellite in other parts of the house
However if everything is o.k the problem is power supply inside.
see the video attached.
Jul 31, 2013 | Televison & Video
Circuit breaker is fine but still no power on one bedroom. PG&E said it might be a bad plug/outlet.
Turn off the circuit breaker and locate the plugs that are on that circuit. There is a good chance that the problem is between the closest working and faulty outlet. Starting with what appears to be the last working outlet on the circuit, check that all the wires are secure in all the fixtures and outlets.
If that does not fix the problem, a varmint may have chewed through a wire inside the wall. If you do not have experience with home wiring, you should get an electrician.
Feb 26, 2013 | Electrical Supplies
TV wont switch on
Check plug for power. Make sure that plug has adaquit power. These TV's take a lot of power make sure breaker pannel is OK. Check fuse in TV. Good luck.
Dec 11, 2011 | Televison & Video
I have an emerson tv and it will not power on at all. The little light wont even come on.
Solution 1 was just step 1. If the outlet gets power and the fuse or circuit breaker is ok, then U have a bad tv. That seems to be the most common problems with lcd's when they go bad. They either give the blinking light and not coming on, or they go completely dead. Most common causes are a bad power supply or a bad board/PCB/Circuit board.
Apr 20, 2009 | Emerson EWL3706 37 in. LCD Television
Power will not work
look inide your house/apartment for the breakers panel - usually in the basement/ground floor closet for house or in the closet for aprtments-check that breakers are on the ON position-plug another appliance in the same plug (example clock or toaster) see if it works-if another apliance works it is an internal problem with the power supply to your tv-get back to me with the model of the tv
Oct 04, 2008 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
