Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Sve47100 oven doesn't heat
shared by 3 users
posted by CHXSailor on Jan 03, 2008
Jenn Air SVE47100B was in the house when we bought it two years ago. On Christmas day when when we were cooking the ham we heard a pop. The clock and digital control was off and the bake element looked as though it was arcing from near the back (not the connections or against the wall, but along the rear section of the actual element). The stove top burners were still operable. We unplugged it and the arcing stopped on the bake element, but the element was broken. I replaced the bake element and the clock control (part number 71002331) with new parts from a local supplier. It all fits back together (did lots of surfing and phoning). Put the power back on and the clock comes on, but when I turn on the bake or the broil, the elements in the oven don't get hot. The control unit will click as though it is trying to heat, and the temperature indicator doesn't rise above 100 degrees, the lowest number that it can register (as soon as you press "bake," it automatically registers "100" regardless of the temperature until it gets above 100 degrees). All connections appear to be tight. I replaced one of the connectors on the red wire that connects into E1 L2 plug. There were some burn marks on that connector and wire as well as the E7 L2 connector on the old clock component. When I activate the broil, the blower comes on, however when the bake is on the fan does not come on when I flip the switch.
Comment posted on Jan 10, 2008
Thanks. The problem was the high limit switch that is on the right side between the burner elements and the top of the oven. It was toasted. Bought a new one for about $7.35. Works like a charm now.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on May 25, 2008
Need the high limit switch. Where can I buy one?
Posted by Guest on Jan 25, 2008
I have the same problem, except my temperature display will register 000.
The BAKE or BROIL display flashes for about 30 seconds then goes off.It just never heats. The elements check out ok.
How do I access this "high limit ". Do I have to remove the entire top of the range to see the top of the oven ?
PR
Best Solution
posted on Jan 09, 2008
FixYa! (100)
refrigdr
Rank:Master Master
Rating: 86%, 20 votes
Some times a company changes vendors for the controls and connections change location. But does the wiring diagram indicate a relay board in the back of range. It could be damaged form the element short
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sve47100 oven doesn't heat:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
Jenn-Air SVE47100 Slide-In Electric Kitchen...
the light on the elect.stove comes on but the right...
i am getting a F9 on front of my oven
on the front control panel flashes "door" but...
I had to interrupt the clean clyle of my Jenn Air Oven due...
I need directions on how to self clean my jenn air oven
Loading problems.
Repair Service
Find Kitchen Range Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
