Question about Vehicle Parts & Accessories
Auto alarm tail lights and dash lights quiet working with alarm installed
  • 204 Answers
Hi chris, with just the limited info you posted on this problem, I would say that when the alarm was installed, it was tied into one of the "hot" tail light wires. Tail lights and dash lights usually are together. Might have blowed the fuse for the tail lights, pull it and check it. Was this a do-it-yourself, or professionally installed? If professional, take it back and have them do it right before something gets shorted out,,, Hope this helps you out,, let us know. thanks, Mechanic
Posted on Feb 05, 2008
Head/rear lights don't work.. But dash/hand warmers/brake light works
No Dash lights, tail lights or Marker lights But Headlights, brake ...
forum.ih8mud.com > Forums > Toyota Tech Forums > 80-Series Tech
Dec 6, 2014 - Now my taillights don't work but Brake lights, Turn signals are good. .... If all the fuses check good with a meter, then head upstream to the ...
Thread: Tail Lights won't work..Brakes,Blinkers,Reverse does ...
www.expeditionportal.com > ... > Toyota: FJ, Hilux, Tacoma, 4Runner
Jan 16, 2014 - 10 posts - ‎4 authors
My bulbs are fine, because the blinkers work, the brake lights work, and so do the reverse, but no tail lights ... I know that the "License Plate" lights are on the same fuse as the tail lights. ... However, I don't have a schematic, so I don't know if that's the case. ... Anywhere I roam where I lay my head is home.
Rear Lights May Not Work Due to Rear Light Socket Plate ...
repairpal.com > Problems > Oldsmobile > Silhouette
Tail lights don't work right. ... I would suggest if you can replace the heads of there bad then do all at once because of you ... Replaced bulbs but still don't work. ... What would make my rear brake lights not to work and also my traction part also.
Dash lights and running lights not working after installing ...
? 1:25
https://www.youtube.com/watch?v=SK36wPXo2EQ
Feb 11, 2014 - Uploaded by 4Runner Nation
I got the same problem with my 91 f150 but just the dash lights don't ... for my head lights n dashlights ...
turn signals, head lamps, tail lamps, auto dome li
Jan 13, 2016 | Saddlemen SNOWMOBILE REPLACEMENT SEAT...
Why isnt my tail lights or dash light not working but headlights and break lights are working on my 1998 Nissan altima?
Hi, the basic elec. Design. Of auto lighting circuits is based on this concept. Dash lights and tail lights use the same feed, For example, if a dash light. Was shorted, you will lose dash and tail lights, Assuming. your stereo has the factory system, this is where. I would start. First chk your fuses, if they are ok, your. issue. may be your dash dimmer,, or worse cas, your muttifunction switch may be def.
Sep 08, 2015 | Nissan Cars & Trucks
Why is my 2001 buick century custom dash lights, tail lights, cruise control not working and dinger is sounding don't know if it is ignition or head light dinger but stops when you close door
dinger is obviously your door open warning, problem 1 solved, dash and tail lights are often on the same circuit in many cars, this will need a new fuse, if this failed when replaced then you have a short, this normally happens in your tail lights
Dec 30, 2013 | Cars & Trucks
97 Nissan Pathfinder dash lights aren't working AND the alarm to turn off the headlights isn't working either.
i know this sounds crazy, but do you have break/tail lights?some cars shut off dash lites when tail/brake lights dont work
Jan 11, 2013 | 1997 Nissan Pathfinder
My tail lights are not working on my 2000 jetta the front lights work the break lights work and the blinkers work all inside lights work just fine
you need new bulbs in tail lights one bulb in each side has two elements one works brake other works running lights the elements in the bulb for tail lites are bad . so just replace bulbs. hope this helps.
Sep 13, 2011 | 2002 Volkswagen Jetta TDI
Dash and tail lights stopped working on my daughters 1991 toyota celica gt. the fuse has been checked and replaced. it was ok. the headlights were recently changed. is it true the dash and tail lights run...
If the tail lights and the dash lights stopped working and the tail light and the panel lighting fuses are both o.k. and you can find no other blown fuses then the problem is most likely the headlight switch.
Apr 23, 2010 | 1991 Toyota Celica
99 Chevy Venture dash board lights and tail lights
So are the fuses getting power, they should be labeled. like tail or ctsy, or inst? The dash lights are usually 5 amps. You will need to get a wiring diagram to ck it out. but you may need to start by looking at the headlamp switch. I cant believe any GM dealer could not help you. Forget anyone from a auto parts store being any help. I can ck tomorrow when at work for a diagram.
Apr 22, 2010 | 1999 Chevrolet Venture
# 4 fuse blew out, replaced fuse and keeps blowing . dash lights do not work, license plate lights does not work, tail lights do not work, head lights work brake lights work . soon as taillights turn on...
I KNOW YOU HAVE AN ELECTRICAL SHORT.WAS AN ALARM INSTALLED OR ANY OTHER TYPE OF ACCESSORY? CHECK WITH DODGE TO FIND OUT ABOUT A RECALL.IF SOMETHING WAS INSTALLED, TAKE IT BACK THERE TO STRAIGHTEN IT OUT IF NOT HAVE A AUTO TECHNICIAN CHECK IT FOR YOU.
Dec 27, 2008 | Dodge Durango Cars & Trucks
You'll have to read through your owners manual. For some time Auto makers have been putting your taillights on the same fuse as your dash lights as an automatic indicator that they are out. I would read through your owners manual and decided where and what fuse will supply power to the taillights and dash lights. If indeed all fuses in connection with the dash lights are good I would suspect the automatic starter.
Nov 29, 2008 | 2003 Ford Focus
Vehicle Parts & Accessories Logo
74 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
