Question about Casio Exilim EX-Z40 Digital Camera
As I lightly touch the set and arrow keys the menu pops up it is really annoying. It fickers on an off. It is like my camera has hot keys or something like that on.
How to you get the camera unprotected
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 13, 2011 | Vivitar ViviCam 8025 Digital Camera
How do you set the date? ViviCam 8025
Press the Home button to bring up the main menu. Touch the Setup function area to enter the setup menu. Touch the down-arrow until you see the "Date" option. Touch the calendar function area to enter the date menu. Touch the left-arrow function area to select On/Off/SetDate, then press Menu/OK to confirm.
Use left/right to select a digit, up/down to change it. Press Menu/OK to confirm and save.
Nov 04, 2010 | Vivitar ViviCam 8025 Digital Camera
How can I set the date?
Press the HOME button to get the main menu. Touch the wrench-and-screwdriver function area to enter the Setup menu. Touch the down-arrow function area until you see the "Date" option. Touch the calendar icon function area to enter the Date menu. Touch the left-arrow function area to select "Set date." Touch the left/right-arrow function areas to select the digit, the up/down-arrow function areas to change. Press the Menu/OK button to confirm the changes.
Aug 12, 2010 | Vivitar ViviCam 8025 Digital Camera
When trying to take picture of my children it is very blurry. Yes they are somewhat moving but it didn't use to be as bad as what it is now. Should I try another setting? Thanks
Check if the white balance setting in the camera menu is set to Auto White Balance (AWB) . Ordinarily, the auto white balance function of the camera can resolve issues with color accuracy, but sometimes certain lighting conditions can still cause discoloration. For example, the entire image may appear blue under cloudy conditions and white subjects may have a reddish tint under incandescent bulbs. If the auto white balance does not resolve the issue, try a different white balance setting, depending on the condition - Daylight , Cloudy , Fluorescent , etc.
If the issue still persists after changing the settings, please initialize the Camera and that should resolve the issue.
To Initialize the Camera,
Press MENU to display the menu of the Camera.
After pressing the FORWARD ARROW key on the Control buttons, go to SETUP and then press the FORWARD ARROW key again.
Scroll to the SETUP 1 submenu using the Arrow keys. Press the ENTER key ( the key at the center of the arrow keys ) once you reach SETUP1.
Then scroll to INITIAZE setting.
Then select the INITIALIZE option using the ENTER key and then select the OK option.
Then press the ENTER key to select the OK option.
After initializing, the Clock Set will be displayed, set the Clock and capture an image and then the images should appear perfect.
If the issue still persists, then the Camera requires to be physically examined to determine the exact issue.
Thank You!
Mar 29, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Set date vivitar camera 8025
Press the Home button.
Touch the Setup icon (the fourth one).
Touch the Down icon repeatedly until you see the "Date" option.
Touch the Calendar icon to enter the Date menu.
Touch the Left-arrow function area to select Set date, then press Menu/OK to confirm.
Use the Left- and Right-arrows to select the digit, the Up- and Down-arrows to set.
Feb 12, 2010 | Cameras
My vivtar 8025 camera locked my pictures so I can't delete the, how do I unprotect them
1. Press the Home button.
2. Enter Playback mode by touching the Playback (right-facing triangle) function area.
3. Press the Menu/OK button.
4. Touch the downward arrow function area until the Protect option comes up.
5. Touch the key icon function area to enter the Protect menu.
6. Touch the left arrow function area to select Lock or Unlock.
7. Press the Menu/OK button to confirm.
This should be on pages 29-30 of your manual.
Jan 03, 2010 | Vivitar ViviCam 8025 Digital Camera
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Unlock Olevia remote control
Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
Nov 14, 2008 | Olevia LT42HVi 42 in. LCD Television
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
Olympus Stylus 410
try to clean the pad using water damped cotton if you are techie, professional fix is needed if you're not.
Sep 07, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Casio Exilim EX-Z40 Digital Camera Logo
16 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
