Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer keeps reinstalling
my printer keeps reinstalling everytime i reconnect the usb cable to my laptop. is this windows vista issue or hp photosmart printer issue?
i would really appreciate your help on this matter. i've been looking for answer, so far i have no luck.
  • maricaren Apr 14, 2008
    Everytime I disconnected my printer from my laptop I have a problem printing anything out. It says that there is a problem and that I do not have the right compatibility. It will scan and copy but will not send from the laptop to the printer.
    1. go to Start
    2. In Search type services.msc
    3. Brings up list
    4. Go to HP Cue Device Discovery Service
    5. Right click
    6. Go to Properties
    7. Hit Stop
    8. In Service Status click Disable
    9. Ok
    10. Restart computer
Posted on Apr 11, 2008
  • 57 Answers
Hi Elvin,
This issue is with the Computer, if the software is not installed completely the computer recognises the printer each time you unplug and replug the USB cable.
However, please follow the below given instructions to resolve the issue.
Refresh the USB Composite Devices:
1. Right-click Computer which is on your computer desktop, and then click Properties.
2. Select the Device Manager button which is on the left pane of the window.
3. Click the Plus (+) sign next to Universal Serial Bus Controllers.
4. Click the USB Composite Device entry to highlight it, and then click Action and then click Uninstall. If a screen appears to confirm the deletion, confirm the deletion.
5. Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
6. A New Hardware found screen may appear, click Next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
This should resolve the issue, if the issue still persists follow the below given instructions to resolve the issue.
Delete the printer and insert the All-i n-one software CD into the CD-ROM Drive of your computer.
Then it will prompt to Install More software, Add a Device or Cancel.
Please click on Add a Device and follow onscreen instructions to resolve the issue.
Even if the issue is unresolved, then try these workaround.
NOTE: These steps can be performed only when logged on to the computer as administrator (for your convenience I have listed the steps to log in as administrator in later part of this mail).
1. Right-click Start, and then click Open all users.
2. Double-click the Programs folder.
3. Double-click the Startup folder to open its contents.
4. Click the all-in-one entry and hold the mouse button down.
5. While holding down the mouse button, drag the HP icon out of the Startup folder and onto an open portion of the Windows desktop.
6. Release the mouse button to "drop" the icon onto the desktop.
After the all-in-one software is prevented from starting, it must be started manually by double-clicking the HP icon on the Windows desktop.
Next, disable HP Digital Imaging Monitor and other HP all-in-one software related files in the start up folder using MS-Config utility.
To do so, follow these steps:
1. Click Start and select Run.
2. Type MSCONFIG and press Enter.
3. Click the Startup tab.
4. Clear all the checkboxes beside HP Digital Imaging Monitor and all other HP all-in-one software related files.
5. Click OK.
6. Restart the system.
This should resolve the issue.
Posted on Jan 10, 2008
If your HP USB printer keeps trying to reinstall itself, then here's the solution:
I have a Windoze XP machine with an HP PhotoSmart C4280. Everytime the printer is switched off and on again, Plug and Pray decides that this is a new USB device and wants to reinstall it. I have noted that many other people have the same problem with different HP printers and also with Vista. There does not appear to be a solution posted anywhere, and HP Support are clueless. So ... after some head scratching, I've managed to fix it, and here's what you need to do:
1. Go to Control Panel > Printers and Faxes and delete the printer.
2. Right-click on My Computer and select Properties > Hardware tab > Device Manager.
3. Right-click on Universal Serial Controllers and uninstall DOT4USB (or similar).
4. Switch off the printer and disconnect the USB cable. Then reboot.
5. Insert the HP Printer CD.
6. Select Uninstall Devices from the menu. Uninstall everything shown in the menu and reboot.
7. With printer still switched off and disconnected, start the installation from the HP Printer CD. Note: there should be no option to Uninstall in the menu.
8. Select Easy install, and wait ... and wait ... and wait .... for HP's bloatware to load.
9. When complete, print a test document.
10. Switch off the printer. You should see a message that the printer is disconnected.
11. After a short period, switch the printer back on, and there will be a message that the printer is ready.
Hope this helps some of you with this annoying problem.
By the way, you can also use the HP PhotoSmart C4280 with Ubuntu Linux. either directly or over the network.
Posted on Feb 20, 2009
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
HP solution center will not open, new intall, usb patch installed running windows vista compatability, system build windows 7,
you need to reinstall the driver making sure it is for window 7 this is an issue with the the new software
Nov 08, 2009 | HP Photosmart 2710 All-In-One InkJet...
Windows keeps re-installing HP Photosmart C4280
I have a customer with Windows XP and the same issue. Told him to unplug the printer cable when starting the computer and/or restarting it. Wait until all auto-start programs have loaded, including and specifically the HP Monitoring Utility program. Once Windows is up and he's at the desktop, THEN plug the printer cable into the computer. He's been doing that for several days now with no duplicate printers installed.
Mar 13, 2009 | HP Office Equipment & Supplies
Driver problem on Vista w/HP Officejet 5610 All-In-One
I have a similar problem on Vista Home Premium (SP1) with the all-in-one HP psc2355. Driver once in a while (why - I don't know!) has to reinstall itself after reboot. Tried clean installs, driver updates you name it.To no avail. I have multiple instances of the driver installed now. Only the latest entry actually works. Can't find any resolution for it anywhere. Only happens with the HP USB driver.
Nov 11, 2008 | Office Equipment & Supplies
This issue occurs when the drivers are not installed properly.
Once remove the USB cable from the laptop and insert the all-in-one CD and click on add a device and follow the on screen instructions and connect the USB cable when it prompts at the middle and complete the process. Then restart the computer and then check for the result.
Jun 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Driver issue
that is the vista problem... test the printer in winxp sp2.. work ok..
but the 3100 series need install driver before conect the printer in the PC usb...
install the driver with the printer unplug usb.. and only conect when program say install printer at the usb..
excuse my bad english
victores from cuba
Jan 16, 2008 | HP Photosmart C3180 All-In-One InkJet...
Computer can't see printer
have u downloaded and installed the latest drivers for this printer in order to install it in windows vista? if not u can get it from
before installing the new drivers and softwares for this printer
> uninstall all the softwares and drivers from your computer
> unplug the usb cable
> run the downloaded application
> when the applicatinon asks you to plug the usb cable, insert it.
thats it!!!
thanks and regards
Dec 16, 2007 | HP Photosmart D7160 InkJet Printer
HP L7580 All in One Device driver reinstall on reconnecting thru USB cable
Everytime I turn on my home computer my HP Photosmart C4180 reinstalls everytime. I constantly have (Copy 1) (Copy 2) etc each time and have to keep changing the most recent as my default. Anyone know how I can solve this PLEASE!?
Oct 30, 2007 | Office Equipment & Supplies
HP Photosmart C3180 All-In-One InkJet Printer Logo
8,533 people viewed this question
Ben Johnson
