Question about Radio Communications
Engine wiring diagrams for 1987 series 4 Non turbo RX7 13B motor. If posible I would like to see a photo of the engine compartment near injectors , and get some help with color codes and loom position
SOURCE: Mk2 1991 gti 8v wiring loom
You have blown up the ecu as a result of not having a good earth connection from the earth lead on the gearbox.
This is a very common problem (done it myself!)
Only solution is to get the ecu repaired or replaced.
You must change the oil and filter before trying to start the car again.
Posted on Jul 02, 2008
doin12volt
  • 233 Answers
SOURCE: fuel injector problem
red and white with yellow go to #1 and #3.
blue and white go to #2 and #4
Posted on Jan 14, 2009
  • 145 Answers
SOURCE: 1990 300zx non turbo has miss on 2 cylinders
dude, i think you have two spark plug cables cross over. go to your local autozone and find a "firing order" if it was a blown head gasket it would show on the compression test but i'm pretty sure its a spark plug cable cross over.
Posted on Jun 25, 2009
  • 133 Answers
SOURCE: peugeot expert 1.9 diesel van 2005 non turbo/ engine wiring fault
If the engine management light is on you should get it plugged in to a diagnostic tool.Also check the wiring with an ohm meter .
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: need wire diagram for 4 wire cord [color code[...
Here is a tip that will help you with that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Posted on May 20, 2010
What should the correct reading be on the pressure dial gauge for setting the diesel pump on a 1.7d opel corsa 2000 model non turbo with a 4ee1 engine
There's this website www.reliable-store.com
They
have books on ALL vehicles.
it covers wiring diagrams, electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
Mar 17, 2018 | Opel Cars & Trucks
Wiring diagram for injector harness for 1987 Ford f-150 4.9 inline 6 engine
http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8038ecd6
Dec 06, 2014 | 1987 Ford F 150
I need timing mark diagram for injection pump replacement 1984 6.9 diesel
now please foregive me if i give the wrong answer here as i have never seen this engine but on the Ford D series commercial engines their is a plug in the back of the injector pump flange housing ,you remove this plug and turn engine till you see the mark ,which is 18? for a non turbo and 21? for a turbo version but this one ?? never seen one here in europe so best of british
Oct 25, 2014 | 2002 Ford F250 Super Duty SuperCab
Need vacume diagram /routing 1984 B series pick up
We do not have thses diagrams. There is a sticker under the hood that has the routing diagrams.
Sep 27, 2012 | 1987 Mazda B-Series
I have a 1987 chevrolet celebrity. A rabbit got into the engine compartment and chewed all of my spark plug wires, the wires on the distrubitor's wiring harness, and a couple others. I've...
Hi, are you sure your fuel pump is running? I'm assuming you have the 4-cylinder 2.5 liter engine. The ECU and the injector are powered by the same wire as the ignition system. See diagram below.
May 14, 2011 | 1987 Chevrolet Celebrity
My Cayenne Turbo is misfiring, jerky and idling erratic
Is it possible you got bad gas, check for vacum leaks in engine compartment,ifyou have one you should be able to hear it with the engine running,Note with a Turbo if the engine has a misfire this could cause damage to your Turbo very expenceive .take care of it asap.
Apr 01, 2011 | 2004 Porsche Cayenne
What is the size of the engine non turbo 4 cylinder
There's several variants of the engine.
There's a 2.2L Inline 4 which came in turbo and non-turbo
There's a 2.5L Inline 4 which came in turbo and non-turbo
There's also a 3.0L V6 as well
But since you asked for the 4 Cylinder, it will either be 2.2L or 2.5L non turbo
Oct 16, 2009 | 1989 Plymouth Sundance
Timing Dpecs for Toyota Supra 87 6 cylinder
1987 non-turbo: 10 deg Before Top Dead Center (BTDC) @700 rpm
1987 Turbo: 10 deg BTDC @650 rpm.
To set the timing, you will need to connect a jumper wire between terminals E1 and TE1 on the diagnostic terminal. This diagnostic terminal is located just aft of the engine compartment fuse box. It is a black plastic box marked "diagnostic" on the cover, which flips open to reveal the terminals inside. There is a diagram on the inside of the cover which explains the terminal positions. On the Turbo model, you need to remove the forward section of the engine cover to gain access to the number one spark plug wire.
Jul 25, 2009 | 1987 Toyota Supra
VACUUM HOSE DIAGRAM FOR 1987 BUICK REGAL GRAND NATIONAL
sign up at turbobuick.com (it's free) then find out who lives near you and check out their car...take some pictures and notes...btw there are a ton of members and I'm willing to bet someone lives near you and most are more than willing to help out a fellow turbo buick owner..or try the link at the bottom...any problems shoot me an email at Mansfieldroof@aol.com
http://www.installationinstructions.com/vin9/vacuum%20hose%20system.pdf
Apr 07, 2009 | 1987 Buick Regal
1987 volvo 760GLE none tubo does it have to fuel pumps
There is one in the fuel tank on my 740GLE (1989) and one near the fuel filter underneath near the driver's door.
Feb 27, 2009 | 1987 Volvo 760
Radio Communications Logo
203 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
