Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer makes noise when it tumbles
We've taken the entire dryer apart and replaced the teflon piece that the dryer spindle rides in. Nothing looked worn. Belt was fine. With the drum out we ran motor and no noise.
  • Anonymous Feb 22, 2008
    High pitch squel
  • amyjoness May 11, 2010
    I have the same dryer. The drum will not move at all. I have checked the belt and motor. I suspect the problem to be in the same are you have described. Did you solve your problem?
    Thank you
  • 283 Answers
"spindle" would seem to refer to the rear drum bearing but teflon would describe the front. Have they both been done? Usually when one is worn out the other isn't far behind. Check the idler arm/wheel for wear. Also motors make a sound when the bearings are bad
Posted on Jan 03, 2008
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Dryer making aweful noise
it has a felt bearing in the front of the dryer on the door the drum rides on and it is probably bad if it is a scraping and squeeling noise
Mar 20, 2014 | Frigidaire GLER642A Electric Dryer
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
There is a plastic oval piece that fits between the inside of dryer door and outer drum. This piece broke apart. Is this the cause of the noise when dryer is on? Close can easily get caught between frame...
Most frigidaire dryers have front felt seals with nylon slides on top that the front of the drum rides on. Without M# can't be sure if yours is like this.
Dec 28, 2010 | Frigidaire Electric Dryer
My dryer is making a high pitch squeeling noise like metal on metal and it starts jumping around hard. please help
You need the rear drum bearing replaced,and while tearing down to replace the rear bearing the front bearing surface should be inspected (Its actually a plastic piece with teflon glide bars attached that the front of the drum rides on)..
Sep 18, 2010 | General Electric Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
The dryer makes a loud noise and also a rubber smell develops after a 1/2 hour of use
My dryer did the same thing. I had to replace the front support glide assembly and needed 4 teflon glides.
The front part of the dryer runs over this plastic piece seen here upside down.
this part is about $50 CAN there are 4 plastic or teflon glides that fit into this.
My dryer had worn through the teflon glides and start wearing away this piece.
My dryer is a GE front load dryer. And I did get a burning smell because the dryer was wearing away the plastic. After the teflon strips wore down.
Hope this helps
Jun 01, 2009 | Kenmore Dryers
GE Dryer model#DWSR483EA1WW
you need to replace the inner plastic "shell" and the teflon pieces that the drum rides on. The dryer drum has eaten thru the teflon slides, and has probably started eating the shell away also.
About $40 in parts available on line will fix the problem.
Jun 08, 2008 | Dryers
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
175 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
