Question regarding KitchAid mixer, Model K45ss. The vertical mixer shaft has play in the gearbox, it makes worn gear noises at all speeds. I adjusted the speed control to manual specs, the speed control works properly. There is also a noise at higher speeds, a whirring noise. I haven't disassembled it yet, asking for advice : Parts availablity, proper repair of unit, it's 30 years old.
Maeveda, Congratulations on your 30 year old KA mixer! Was it a wedding present? Do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use K45SSW select Parts List (1) and then check to see it this matches your mixer). You can check on page 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. It will be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com (this vendor the best prices for my wife mixer's parts, but sadly they had to back order them, which was disappointing to SWMBO). Prices for the same part vary widely between vendors, so do your comparison shopping. Here's a link to a site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA
My K45SS 250 Watt mixer has been sitting for approximately 6 months while I was away. I find that...
(More)
My K45SS 250 Watt mixer has been sitting for approximately 6 months while I was away. I find that there is grease in the bowl and around the beater connection. Do I need to take it apart and oil it and if so, what kind of oil?
kitchen aid k45ss classic unscrewed black plastic screws and springs on housing and replaced and now...
(More)
kitchen aid k45ss classic unscrewed black plastic screws and springs on housing and replaced and now it won't run
