Chain Saws
Problem for Chain Saws
Generic problem for all Chain Saws
My chain saw is a Mc Culloch - 2116 AV mod...
By h_mercier on Nov 02, 2009
My chain saw is 2116 AV model bought in 1994- Serial 11-010401 and model # 600035-20. Recently, although the saw is in perfect operating order the chain oiling device stopped functioning: can you tell me how to get it to work properly?
Best Solution
posted on Nov 03, 2009
Very Helpful)
dontbother10
Rank: Guru  Tools - Building & Power  Expert
Rating: 98%, 847 votes
This is a little complicated so I’m going in small steps.
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “11-600035-20”
Click “Powerhead Assembly” Item 1 is the oil pump $9.48
You can construct a veryry detailed parts breakdown for your saw with a little effort. I recommend you do it.
If you were looking for a sprocket earlier it is on the same detail page as the oiler $12.05.
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
I’ve found McCulloch parts here I can get no where else and they are reasonable.
Given this detail and a little effort on your part she can oil again. Even this thread is closed you can still add to this thread below the advertisements. I'll try to remember to check for additional questions. Good Luck with your project
Lou
Comments:
Nov 03, 2009
- Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Nov 03, 2009
- Let's keep this quiet. Here is a complete IPL for your saw without jumping through hoops. I usually check for Mac Parts here when accessing, I haven't had much luck. Your oil pump isn't listed
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600035_20_Eager_Beaver_2116_IPL_211318_01.pdf
Thank you for the kind words
Good health and happiness
Lou
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thanks a lot: very helpful info! Great source of parts supply! Thank you for your help. " - h_mercier
Solution #2
posted on Nov 02, 2009
Helpful)
mrfixit-jerr
Rating: 94%, 7553 votes
hello sir, what i would do is remove the bar and chain.in the side of the bar are a couple of holes that feed oil from the saw into the bar grooves.make sure these are clean of any debris.you can use solvent and a small drill bit to clean out holes.than look at the saw where there is usually a wear plate and make sure the groove there is also free of debris.lastly i would start the saw without the bar and chain and look for oil coming from the groove area described above.if nothing coming out than you have a problem with saw motor and would have to go deeper into it,you can also try rinsing out tank with solvent and running engine to see if fluid comes out.hope this helps,MrFixIt, oh could you please rate this solution,thank you***
Was this helpful?
Yes
No
Asker's Testimonial
" Thanks for your suggestions: I have tried all that you suggest but am still unable to obtain oil flow ! I will try to rinse the oil tank again. " - h_mercier
Popular Solutions for Chain Saws
Questions and Unsolved Problems for Chain Saws
Answer
flymo 2200 chain oil leak when machine is running
Answer
I'm trying to find an owners manual for a 1968 McCulloch model 200 gasoline chainsaw
Answer
Once my Stihl MS310 saw warms up, it stops running when I release the throttle trigger. Sometimes I... (More)
Answer
I need a manual on how to replace fuel lines and rebuild carb on my Eager ****** 2014
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Chain Saws:
Top Chain Saw Experts
Rank: Guru Guru
Solutions: 3969
Experience: ten years experience,school trained,own business
Ask Me
Find more Chain Saw Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
