Question about Samsung Digimax S630 Digital Camera
Don't work. I heard people said that i have to put in 2500 batteries, and i did, but its the same it beeps three times. What is wrong with this camera. Please help me i really want i to work.
  • Anonymous Jan 05, 2008
    do u use 2500 or higher recharble batteries and then there is a setting on the camara that lets u choose what type of battery
    Scholar:
  • 39 Answers
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just set the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
It really doesn't matter if you'll be using 2500mAh. So long as those are the recommended batteries, those will work.
Posted on Jan 12, 2008
6ya staff
SOURCE:
MACHINE WILL NOT INITIALIZE RIGHT OUT OF THE BOX. JUST BEEPS
Make sure the switch is on REG mode. Make sure there are NO batteries in it. Turn power off at wall for a few minutes. Turn on and it should beep three times. Then put the batteries in. If it beeps more than three times, the printer is probably jammed or faulty. Make sure it can turn. Try taking the ink roller out as it sometimes gets sticky and jams the printer.
Mar 23, 2016 | Sharp XE-A101 Cash Register
I put new batteries into the camera but it continually tells me "low battery". What's wrong??? Do I need a specific brand or type of battery?
Yes, you are correct.
Digital camera need a high drain battery like NIMH or ALKALINE type, and don't a multi purpose ( standard battery).
My favorite battery is Energizer 2500 mAH ( recharged type).
Please check the battery you are using right now and replace it as guided above. If there is no internal problem on your digital camera, this recommend batteries will working just fine.
Regards,
Aug 15, 2011 | Cameras
I hear beeping tone in my cpu when i plug it
When the computer makes those funny sound via the system speaker, it's not doing it because it wants to be heard. The computer is trying to talk to the operator/technician and tell them what's wrong.
So here are some codes to give you an idea of what might be wrong with your PC.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Nov 30, 2009 | Computers & Internet
Digimax s500 cutting off
BAtteries draws down too quick...
Use 2500 mAh or better for longer life the higher the number...
eveready bunny is sometimes not in all their work
Jul 27, 2009 | Samsung Digimax S500 Digital Camera
Computer beeps three times and will not start
Clear CMOS/ Remove battery for 10 minutes, reinstall battery & wait for another 10 minutes before turn on. Three Beeps means RAM is defective/ not detected.
Jun 27, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
Camera not working
Usually when the camera beeps 3 times. It means the battery is low. Then it turns right off. What kind of batteries are you using for your camera?
Dec 27, 2007 | Samsung Digimax S630 Digital Camera
TROUBLE SHOOTING
We had the same problem. It would beep three times then shut off.
The lens was stuck in the out position. My son played with it until it loosened up and it works now. It had nothing to do with batteries.
If yours is stuck out. twist and push until it goes back in.
Good luck
Oct 19, 2007 | Samsung Digimax S500 Digital Camera
Singer 2638 - three "beeps" when the foot pedal is pressed
when I stiches any cloth the thread gets lose on backside of cloth or some times it breaks how to solve is problem I am not understanding please help me.
Aug 08, 2007 | Singer 2638 Mechanical Sewing Machine
Samsung Digimax S630 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
