Question about Visonik 10" 500-Watt Single Bandpass Subwoofer Enclosure Car Speaker
Installing visonik bass system
How to run the wires to connect the amp and get power
  • 146 Answers
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Posted on Jan 03, 2008
Don't know how to hook up the amp. It came with a wiring kit and I have no idea on how to hook it up.
You need to connect the Power wire (Most likely red wire with fuse) to the battery and run it to where you put the amp. You need to also drill a whole in the car and make sure it is grinded up and bare metal is shown. Screw the ground wire there with a bolt and nut. You will then need to run the rca cables from the amp location to either the back of the headunit if it has RCA outputs, or use a Line out converter, you can get them at best buy. Then you need to find your cars wiring harness code and figure out which is the remote ignition turn on and tap into that and feed that wire back to the amp to turn it on. Hook all wires up and make sure power and ground DO NOT TOUCH.
Jul 24, 2011 | Visonik Dual Bass Box with Amplifier Car...
I wanna put it into my car myself but dont know how and was hoping for a lil instruction
you will need a amp install kit witch comes with a 15 ft patch cable power line for amp and a blue line for remote. these wires run from the radio to the amp. The blue wire is called remote it turns the amp on or off depending on the radio state. the patch cable is rca jacks on both ends the back of the radio should have the female part of the rca jacks hanging from it. The other end goes into the amp. and last but not least the heavy red wire will go from the battery to the amp usually there is a fuse holder that you need to put between the battery and the amp. As far as grounding just ground the amps negative to the car chasis some where.
Good Luck Hope this helps
May 04, 2011 | Visonik Dual Bass Box with Amplifier Car...
I dont know why my amp is not getting any power? the power light wont even come on? everything seems to be connected properly, but its not getting any power?
Make sure you have both power wires hooked up. There's the main power lead/cable going to to the battery, and the trigger wire from the accessory wire from the radio (antenna) to the amplifier. Hope that's what you were looking for. If so please rate my assistance and leave a testimonial.
Dec 30, 2010 | Visonik Dual Bass Box with Amplifier Car...
Amp wont turn on..Visonik vb212pkw
Well you have a high impedance path to your amp. If you have an inline fuse that should have blown. Car batteries don't have a current limiting feature HA The only explanation would be that the amount of current passing through the wire is causing a large voltage drop due to a large impedance. What gauge wire are you using? Here is an example.
18 ft of 8 gauge wire would have to be passing about 400 Amps of DC current to yield a voltage drop of that magnitude. The wire would melt and all hell would break loose. So there has to be a break in your wire somewhere.
Dec 18, 2009 | Visonik VB212PKG Car Audio Amplifier
Visonik V12D4
i would wire the coils of each sub in series which would yield an 8 ohm resistive load per sub - and then wire the subs in parallel to the amp which would bring the resistance back to 4 ohms for a bridged load which will give you max power handling from the subs and draw the full power of the amp at the same time
Jun 18, 2009 | Earthquake Sound PH800W.2 Car Audio...
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
Visonik 10" 500-Watt Single Bandpass Subwoofer Enclosure Car Speaker Logo
300 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jerry Umali
ELECTRICKS
ELECTRICKS
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
