Sewing Machines
Generic problem for all Sewing Machines
Sewing Machine
posted by genella on Jan 03, 2008
I have my machine threaded correctly but when I try to sew the needle goes through the cloth and goes a stitch then seeps to pull up like three threads under the cloth and wads up and wont go.
Comment posted on Jan 04, 2008
the problem was discovered to be the thread was incorrectly fed through from the top tension disk to the take up lever. Which caused it to not have the correct tension.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1459 votes
Make sure that when you thread the machine up the presser foot is up and make sure the thread goes between the tension discs and not to one side, top tension between 4 and 6, make sure you have the bobbin in the correct way round, bobbin turning anti clockwise, make sure the needle is in the right way round, flat side to the back.
Rating Locked! (?) genella has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sewing Machine:
I don't want to Accept this solution
Can you Help with these Sewing Machines problems?
PfaFF Tiptronic 2030
gear by forcing it I could have done that myself can I get...
Sewing Machines
necchi 544 Merilla. Sews a combination of a few straight...
Brother PE-150V Computerized Sewing Machine
And neither thread is cut. It also keeps breaking...
Baby Lock Imagine
I was serging a rolled hem when blade assembly quit moving...
Janome 6019QC Mechanical Sewing Machine
I cant figure out why my tread keeps breaking and i can`t...
Loading problems.
Repair Service
Find Sewing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
