Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Chilling Fault The freezer works fine all the time, however the fridge works for about a week and then stops working. Then after 4 days starts working again? Any ideas, its getting to be a real pain.
  • 833 Answers
You are probably frozen up which causes the fan to freeze up. Thoroughly defrost the unit...if necessary, stop it for a day or more until all the ice melts. Restart. Cut down on 'window shopping', storing uncovered liquids. Check the door gaskets, clean if necessary or replace.
Posted on Jan 03, 2008
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2016 | Hotpoint Refrigerators
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
I bought a Zanussi ZF4 fridge/freezer second hand about two weeks ago. When I installed it I made sure that it was left to stand for 12 hours before turning on and that it was cleaned thoroughly. The unit...
It is possible that it is the thermostat, and if not as you hear the compressor starting shortly then stopping, and redoing that many times.
Your compressor is certainly out of order and must be replaced by a professional, that means to dessolder the current compressor, and replace it with the new one, and change the gas.
So major intervention and at least 2 hours of work.
In the end, you will have a new heart for this great fridge.
Dec 03, 2009 | Zanussi ZF4 Top Freezer Refrigerator
My problem is -freezer fine-but fridge has stopped chilling
Sounds like the freezer/refrigerator circulating fan is wearing out. When this fan starts to wear out the fans force is reduced to a point that it will keep the freezer cold, but doesn't have enough force to circulate air thru the refrigerator. The minimum cost to repair this problem is around $300.00
Jul 11, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
The freezer is working fine but the fridge aint chilling
sounds like defrost problem unplug for 4 or 5 hrs with doors open turn back on if works fine then defrost problem call tech check and make sure u hear your evap fanm working thats possibilty to
Mar 16, 2009 | Refrigerators
I have ? for model # ET1MHKXMQ00
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
Jan 24, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool freezer and the refrigerator.
Chances are your defrosting clock is stuck or quit working.
The clock works as timer to set time for defrost, at which time it stops the compressor, and turns a heater tube next the cooling coils to melt ice. It depends on your expertise if you want to try replacement,as most replacement are universal, and some rewiring is sometime involved. The clock is usually in front at the bottom behind the removable grill, or in the back. It looks like a square box with a dial that has a one way turn knob. To check use flat screwdriver to slowly turn dial (you can only turn one way) until the compressor stops, then wait to see if compressor starts back on it's own (it might take as long as 30 min.).
If it does not start it's bad and need replacement. Of course you can turn dial again until it starts again so you can use fridge. If it does start it could still have been the problem where the clock got stuck, and you got it going again by turning the knob, but let it run. If it works for a while and then have the same problem again the replace clock.
Hope this helps you
Dec 12, 2007 | Whirlpool (ET8FTEXSQ) Top Freezer...
Samsung side by side srs580dw stops freezing and chilling
Since the temps on the display don't show correctly I'd assume something is wrong with that. If the temps are sending info out that the unit is OK and at proper temp (when it's not) then the compressor won't turn on because it thinks the fridge is cold enough. Soooo... I'd suspect that control board. It's item 48 on this diagram http://www.partselect.com/Schematics/Maytag/SS10-2.gif
Jan 13, 2007 | Samsung RS2630WW Side by Side Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
