Web Cameras
Problem for Sony Web Cameras
Generic problem for all Sony Web Cameras
I have a Sony SNC-RZ30N
By bferrell438 on Nov 02, 2009
I have a Sony SNC-RZ30N webcam that I can only view the video from on a very few computers, all of my more up-to-date computers only see a blank screen in the browser view.
Comments:
Nov 03, 2009
- There are no drivers for the webcam, it runs a website on port 80 on the IP address that I assign. When you go to the address (webcam.velocityxl.com-redirected to IP 192.168.2.5 locally) index.html gives you the option of an ActiveX or Java viewer page. One machine can view the video stream (Active or Java in IE or Java in Firefox on WinXP), one other desktop with XP cannot view in either browser and one Vista laptop cannot view in either browser. Both of the machines that can't open the stream can control the camera and take snapshots, so it seems to be an issue the browsers not having the correct JRE environment for the jar that the camera is loading to view the stream.
Nov 03, 2009
- I believe my issue is getting the correct java installation and settings to view this camera's html server....
Nov 03, 2009
- There aren't any drivers for this camera guys, it's an IP camera that makes it's video available as a webserver. I've checked that it has the very latest firmware (3.15 as I recall) and downloaded all of the available software and manuals for this camera. As I mentioned, I can view this camera's webserver page fine from some computers but not others. The issue is not with the camera, it's with the computers trying to view this content, and I suspect the versions of java on those computers trying to load the this camera's Java applet.
Nov 03, 2009
Nov 03, 2009
- Could the "experts" stop recommending that I install a driver for an IP camera? It's really not helpful, so either read the problem description and understand something about this camera or pass please.
Nov 03, 2009
- The firewall is not blocking the content, it is only using port 80 as it's streaming it via a webpage, and I've tried completely disabling the firewall (ESET SmartSecurity). I believe the issue is the version of Java, as I get the animated Java logo rather than the image on some of the machines. You can try to connect to the camera yourself to see the java applet loading on your system at http://webcam.velocityxl.com
Nov 04, 2009
- You have any other ideas, or should I go onto to someone else?
Nov 04, 2009
- First, the link to the webpage is not applicable because this is not a USB webcam, it's an IP-based webcam, so there is no point in looking for it in the control panel.
Second, as regards the firewall, as I said before I've completely disabled the firewall to no affect, though it works just fine on my work laptop, so I don't know what you're saying about Java opening a custom port, this is all working through port 80 as it's just a web page. The camera works fine, totally, from my work laptop with no special settings, and I can control the camera from the computers that can't view the stream, so they are clearly communicating with the java applet (it's showing the buttons), but the stream viewer seems to not initialize. I've included a screen shot here to help walk you through the issue I'm having. If you're Java ports/firewall comment goes deeper than turning off the firewall please say more, because I think it's pretty clear that the firewall is not the issue and this is working on http port 80,
http://www.velocityxl.com/webcam_shot.jpg
Nov 04, 2009
- Again, I TOTALLY disabled the firewall, so even if that were correct, the firewall would not be blocking it, as I mentioned, the firewall was doing nothing at the time. I also did not install a Java application, so it did NOT ask me for a port, as I mentioned, and showed you in the screenshot, this camera is working entirely through the browser Java plug-in, and I know what port it's using because I set that on the camera webserver configuration. Also, since I have some computers working with the camera, I have a basic understanding of how it works. If you read the manual on this fine camera, it states that it wants an old version of the Java plug-in, which is most likely the issue. Unfortunately I've tried to install these older versions of the Java plugin (1.3.1_02, 1.3.1_03, 1.4.0, or 1.4.0_01), but as those versions of the JRE expect Netscape Navigator, I'm having difficulty getting them to activate within Firefox.
Manual (see page 8)- http://tinyurl.com/yzyafmh
Nov 04, 2009
- Please read everything posted before offering a solution, there's a lot of information included.
Nov 04, 2009
- ah, no, that's not the issue, and no, I'm not trying to share across many computers at the same time, though on my LAN I should have the bandwidth to do that if I wanted to.
Nov 04, 2009
- I'm trying to view on the LAN and remotely. I know the port (80) is not being blocked because I read the problem notes, and thus know that I can view the camera on the LAN and remotely with one of my PCs (both ActiveX and Java viewers). I've tried deactivating the firewall on the PCs where I can't view the stream (note I can open the page and camera controls, as I've mentioned several times, internally and externally) to no affect. Does anybody know anything about these older versions of Java that the camera wants, and how to get them to work properly with Firefox 3.5.x??
Nov 04, 2009
- Seriously dude, could you please read the problem description and try first to understand before you post this ****. I've mentioned about 10 times that this is an IP webcam and doesn't have any drivers to install. Quite tedious...
Nov 04, 2009
- Still looking for someone with experience with IP cameras, with likely a java plug-in version incompatibility.
Nov 05, 2009
- Solid suggestion, but I have tried that already.
Nov 05, 2009
- I've tried the latest JAVA, Java 5, 1.4.1_03, 1.3, etc. You'll notice from my previous posts that the camera claims it's webpage requires a very old version of the Java plug-in. I've also tried various flavors of IE8/7/6. I haven't tried IE8 in compatibility mode, so I will try that. My one laptop that has no issues with the camera's web page works with both Firefox (3.54 using the java plug in for Netscape Navigator 1.4.2_03) and IE6 (6.0.2900.2180 using MS Jit for JRE 1.4.2_03), so I suspect if I could get that version of JRE to install properly on my other machines (the laptop that views properly is corporately configured) that I would probably be home free. Unfortunately when I try to install it won't integrate with Firefox properly. I'll give the IE8 compatibility mode a shot as well though.
Nov 06, 2009
- Ah, yea, read the whole problem discussion...
Comments: Nov 03, 2009 - There are no drivers for the webcam, it runs a website on port 80 on the IP address that I assign. When you go to the address (webcam.velocityxl.com-redirected to IP 192.168.2.5 locally) index.html gives you the option of an ActiveX or Java viewer page. One machine can view the video stream (Active or Java in IE or Java in Firefox on WinXP), one other desktop with XP cannot view in either browser and one Vista laptop cannot view in either browser. Both of the machines that can't open the stream can control the camera and take snapshots, so it seems to be an issue the browsers not having the correct JRE environment for the jar that the camera is loading to view the stream.
Nov 03, 2009 - I believe my issue is getting the correct java installation and settings to view this camera's html server....
Nov 03, 2009 - There aren't any drivers for this camera guys, it's an IP camera that makes it's video available as a webserver. I've checked that it has the very latest firmware (3.15 as I recall) and downloaded all of the available software and manuals for this camera. As I mentioned, I can view this camera's webserver page fine from some computers but not others. The issue is not with the camera, it's with the computers trying to view this content, and I suspect the versions of java on those computers trying to load the this camera's Java applet.
Nov 03, 2009 - Could the "experts" stop recommending that I install a driver for an IP camera? It's really not helpful, so either read the problem description and understand something about this camera or pass please.
Nov 03, 2009 - The firewall is not blocking the content, it is only using port 80 as it's streaming it via a webpage, and I've tried completely disabling the firewall (ESET SmartSecurity). I believe the issue is the version of Java, as I get the animated Java logo rather than the image on some of the machines. You can try to connect to the camera yourself to see the java applet loading on your system at http://webcam.velocityxl.com
Nov 04, 2009 - You have any other ideas, or should I go onto to someone else?
Nov 04, 2009 - First, the link to the webpage is not applicable because this is not a USB webcam, it's an IP-based webcam, so there is no point in looking for it in the control panel.
Nov 04, 2009 - Again, I TOTALLY disabled the firewall, so even if that were correct, the firewall would not be blocking it, as I mentioned, the firewall was doing nothing at the time. I also did not install a Java application, so it did NOT ask me for a port, as I mentioned, and showed you in the screenshot, this camera is working entirely through the browser Java plug-in, and I know what port it's using because I set that on the camera webserver configuration. Also, since I have some computers working with the camera, I have a basic understanding of how it works. If you read the manual on this fine camera, it states that it wants an old version of the Java plug-in, which is most likely the issue. Unfortunately I've tried to install these older versions of the Java plugin (1.3.1_02, 1.3.1_03, 1.4.0, or 1.4.0_01), but as those versions of the JRE expect Netscape Navigator, I'm having difficulty getting them to activate within Firefox.
Nov 04, 2009 - I'm trying to view on the LAN and remotely. I know the port (80) is not being blocked because I read the problem notes, and thus know that I can view the camera on the LAN and remotely with one of my PCs (both ActiveX and Java viewers). I've tried deactivating the firewall on the PCs where I can't view the stream (note I can open the page and camera controls, as I've mentioned several times, internally and externally) to no affect. Does anybody know anything about these older versions of Java that the camera wants, and how to get them to work properly with Firefox 3.5.x??
Nov 04, 2009 - Seriously dude, could you please read the problem description and try first to understand before you post this ****. I've mentioned about 10 times that this is an IP webcam and doesn't have any drivers to install. Quite tedious...
Nov 04, 2009 - Still looking for someone with experience with IP cameras, with likely a java plug-in version incompatibility.
Nov 05, 2009 - Solid suggestion, but I have tried that already.
Nov 05, 2009 - I've tried the latest JAVA, Java 5, 1.4.1_03, 1.3, etc. You'll notice from my previous posts that the camera claims it's webpage requires a very old version of the Java plug-in. I've also tried various flavors of IE8/7/6. I haven't tried IE8 in compatibility mode, so I will try that. My one laptop that has no issues with the camera's web page works with both Firefox (3.54 using the java plug in for Netscape Navigator 1.4.2_03) and IE6 (6.0.2900.2180 using MS Jit for JRE 1.4.2_03), so I suspect if I could get that version of JRE to install properly on my other machines (the laptop that views properly is corporately configured) that I would probably be home free. Unfortunately when I try to install it won't integrate with Firefox properly. I'll give the IE8 compatibility mode a shot as well though.
Nov 06, 2009
- There really isn't any useful information there for me.
Nov 07, 2009
- Yes, of course I have, and if you read the full problem description and responses you'll see that I have some computers that work completely fine with the camera, and some (running XP and Vista) that have issues whether I use IE or Firefox.
Nov 07, 2009
- Yes, the issue is definitely on the computers that cannot see the camera as there are many (probably even yours (webcam.velocityxl.com) that can view the camera just fine. The manual indicates that it requires an very old (see in the notes above) version of the Java plugin which I seem not to be able to install properly on Firefox 3.5 or IE7/8.
Nov 07, 2009
- That's just non sense. Since I can view on some computers and not others, the cable to the camera is clearly fine, as the camera connects to the network not the computers directly, there is an issue with the browsers on the computers that can't view the stream. As I've mentioned repeatedly, even these computers can grab a still from the camera or move it, they just can't watch the live stream.
Nov 08, 2009
- I have multiple machines running XP that can view the screen (using IE or Firefox). I have multiple machines running XP and Vista that cannot view the stream. As I've mentioned endlessly (have you read my other replies?), there are NO drivers for this camera, it's an IP camera. The port forwarding is working fine, as I can view the camera from the LAN or from the internet with the machines that can view it (http://webcam.velocityxl.com). The computers that cannot view the stream can also open up the camera's webpage, take and view jpg snapshots, and control the camera. The computers that cannot view the stream cannot in either Firefox or IE 7 or 8. If you read the manual on this fine camera, it states that it wants an old version of the Java plug-in, which is most likely the issue. Unfortunately I've tried to install these older versions of the Java plugin (1.3.1_02, 1.3.1_03, 1.4.0, or 1.4.0_01), but as those versions of the JRE expect Netscape Navigator, I'm having difficulty getting them to activate within Firefox. Manual (see page 8)- http://tinyurl.com/yzyafmh
Nov 09, 2009
- for the millionth time, this camera doesn't use a driver, it's an IP camera, read the full discussion for more details.
Solution #1
posted on Nov 03, 2009
Somewhat Helpful)
webmaster21
Rank: Guru
Rating: 91%, 1066 votes
1. Go to the Windows Desktop, click on the "Start" button, and then click "Run" or "Start Search" if you are using the Windows Vista operating system.
2. Type the following text into the text box:
1. "devmgmt.msc" Click OK.
2. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window.
3. Choose the "Scan for hardware changes" option from the drop down menu that appears.
4. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 05, 2009
Somewhat Helpful)
eng_omran_77
Rank: Guru  Computers & Networking  Expert
Rating: 91%, 308 votes
I got it to work on my laptop computer using the ActiveX Viewer.
I use Windows XP with SP3 installed, & Internet Explorer 6.0
No JRE environment installed on my system.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
avmann
Rank: Guru
Rating: 92%, 36 votes
If you are using Internet Explorer
Select Tool from the menu bar of Internet Explorer, then
select Internet Option and the Advanced tab in
sequence, and check JIT compiler for virtual machine
enabled (requires restart). Then restart Internet
Explorer. Hope this helps!
Comments:
Nov 05, 2009
- You've probibaly checked this already, but check this page out; "Other software that may block JavaEven if Java is installed and enabled in Firefox, it may be blocked by other software or Firefox add-ons, such as the following:
  • The NoScript extension for Firefox will block Java. For more information, see the NoScript FAQ
  • The Adblock extension for Firefox can also cause Java to stop working if OBJ-TABS are enabled. For more information, see the Adblock Project forum."
Was this helpful?
Yes
No
Solution #4
posted on Nov 04, 2009
Somewhat Helpful)
niquose
Rank: Wiz  Computers & Networking  Expert
Rating: 84%, 75 votes
are you trying to view remotely or just locally within the same network?
If it is just within the network, ActiveX may be blocked from the browser.
o to Start -> Control Panel and double click
Internet Options. Click on the Security tab. Click on the
Custom Level button. Scroll down to the "ActiveX Controls and
Plugins" section.
Download signed ActiveX controls -> Prompt
Download unsigned ActiveX controls -> Prompt
Apply changes, re-open the browser and install Active X when prompted.
If you are trying to access remotely, make sure that the ports used by the camera are enabled/allowed on the firewall (both software and hardware firewall such as routers).
Hope this helps.
Was this helpful?
Yes
No
Solution #5
Somewhat Helpful)
dell-net
Rating: 85%, 242 votes
are you trying to show the video to several computer at the time? maybe your band witch aren't enough?
Comments:
Nov 05, 2009
- so you have the latest java? try to change the settings in your camera so its shows the video in other format then java. also if you using IE8 try run in compatibility mode in the browser. also be sure that the camera has latest firmware.
Nov 09, 2009
- any diff with compatibility mode ? seems like a bigger problem, you should contact your cam manufacture and ask them, maybe them have any good ideas.
Have you tried to restart you cam? also test your cam in Chrome Browser(google browser).
I tested the cam in firefox, explorer and Chrome and it worked perfectly. I have windows7 + newest browser and java.(java 6 standard edition. build 1.6.0_15-b03)
Its something wrong with you java motor or its a program collision with the java. do you have any other cam, like a webcam. or something other that use java?
Uninstall all java program. then run this-> Download the Windows Installer Cleanup Utility package now. try to install newest java and try the cam.
Nov 18, 2009
- Did you figured it out ? I think its a computer problem. maybe a DEP problem. you should try to turn it off completely.
http://support.microsoft.com/kb/875352
Was this helpful?
Yes
No
Solution #6
Somewhat Helpful)
njvinod
Rank: Wiz
Rating: 85%, 437 votes
The firewall must be blocking the port in whic the cmera sends the data, so you might be seeing only the blank screen..
To resolve this issue, please unblock or disable the firewall...Also disable any third party firewall and anti virus firewall..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Comments:
Nov 04, 2009
- WHen you install and run java, it runs on different custom port..
Check whether the port is opened in that computer also check whether the Java application is added to exception in the firewall list,by default the Java would be added to firewall blocked list
Nov 04, 2009
- YOu were wrong, Not all the pages work on port 80....Only one ip per time can use port 80, when the port 80 is occupied, the system used user custom ports sauch as 8081, 8082 etc....
My final thing is, when you install jav application on the sytem it asks you to specify the port number that to be used by the application by default it would be 8080..
Just open the windows firewall and add java aplication as exceetion, throught the exception tab in the windows firewall...Try this it should work..If this doesnt work, You can get transferred to another Expert..
But if feel this is the apt solution later, then please do accept this solution
Thanks
Was this helpful?
Yes
No
Solution #7
Somewhat Helpful)
justaskjoe
Rating: 85%, 2299 votes
It is likely that you will need to download a newer driver. these downloads are free. just google Sony SNC-RZ30N webcam driver and you will be able to select one. regards, J.
Comments:
Nov 04, 2009
- The way your computer is programmed, it will trash the old web cam driver before loading a new one. Therefore, expecting numerous computers of different ages too all operate with the same driver is actually not possible. Hope that helps.
Was this helpful?
Yes
No
Solution #8
posted on Nov 02, 2009
Somewhat Helpful)
88smokey
Rank: Wiz
Rating: 85%, 276 votes
uninstall and re-install the driver for the webcam.
Was this helpful?
Yes
No
Solution #9
posted on Nov 08, 2009
Not Rated)
alenorm
Rating: 85%, 188 votes
you need to get an updated driver, some of the videos may be saved on an old formats, look for a software that can see old and new...let me know
Comments:
Nov 10, 2009
- I ma sorry that you still have the issue and see that you are upset from restating your problems to everyone...no one can see any communication between you and other techs and that is why you may get same answers...as far as Java, I did try this on my system by deleting all Java from the system as my univeristy uses old ver. and my research use new one, so I deleted all javas and installed the old one and booted the system with it and after I got to my site I reinstalled firefox in another directory with new jaava and now if I need to go to my class I start one browser and if I need research I start MS browser but I can not use both at the sametime...you need to have one vers. only on the system to work good...sorry again and good luck
Was this helpful?
Yes
No
Solution #10
Not Rated)
DSandles
Rank: Wiz
Rating: 85%, 51 votes
Welcome to Fixya, and thank you for trying out our services.
To definitively solve your issue, I would need to know what operating systems the newer computers are running versus the older computer systems where the webcam works..
Generally speaking though, this sounds like a driver issue..
Try going to Sonys website and downoading the newest drivers for whatever operating system ( Vista, XP, Windows 7) that the computers are running that cant view the webcam..
If downloading the newest software doesnt work, then try right clicking the link to the webcam software on your computer, left click properties, go to compatibility, and try running it in compatibility modes for older versions of windows..
If none of this works, please respond with the operating system for the computers that arent running the webcam properly..
And also the operating system for the computer that is running the cam properly.
Was this helpful?
Yes
No
Solution #11
Not Rated)
leethedeuce
Rating: 86%, 542 votes
There can be a lot of reasons for this. I assume you have the camera hooked up through ethernet. There are a lot of settings involved. Have you referenced the manual at all? You can download it here:
http://ws.sel.sony.com/PIPWebServices/RetrievePublicAsset/StepID/SEL-asset-43076/original/usesguidesncrz30nv4.pdf
If you still have questions let me know and please include as much detail about the problem as possible.
Thank you,
lee
Was this helpful?
Yes
No
Solution #12
posted on Nov 07, 2009
Somewhat Helpful)
dwane4444
Rating: 88%, 83 votes
If you can view video on some computers it means that everything is working. So it is either an error in the IP configuration or a connection problem.The only problem that I can think of with connection is that for connection to a single computer you need a "crossover" cable, for connection to a switch or hub you need a "straight" cable.
As for IP configuation - check the one that works and set the one that does not to the same settings.
Comments:
Nov 08, 2009
- My apologies - the way that the questions are presented to the 'Experts' is not very good. We see the question but not the comments. We have to select the question to lock it so we can answer, still without seeing the comments. If we unlock the question then we can see the comments but this means another expert can lock the question and I would not then be able to answer it. This is what happened in this case it was not until I had given you a very basic answer that I was able to see the comment and learn more about the problem. This must be very frustrating for you!
Was this helpful?
Yes
No
Solution #13
Somewhat Helpful)
drifterK
Rating: 85%, 431 votes
ok ..I ssumed that you have the right drivers and you just open it from the all programs ...and it opened a window that is black ...when you clicked the AMcap in the all programs from start ..
this means that you have to enable preview on the window...probably its in the second button ...after that you have to alocate space and choose a location for the file ..in order to capture...
But....! the main function on a web cam is using it for video calls using a instant mesenger like yahoo messenger or skype or msn ....
if the camera have the right driver for the operating system you use in a certain computer ...than on the window that opens when you click camera symbol on conversation window..( to invite the other to view your web cam ) you will see images..and the number of people that you granted acces to it ...
if you have issues let me know by commenting ...
Comments:
Nov 07, 2009
- I think Ive made a confusion ...you didnt specified the problem in the question and this was the issue...anyway ...the problem seams to be in the add-on's on the browsers into the computers that didnt see the cameras address on web ...
Nov 07, 2009
- Did I mentioned to check the filtering from an admin point to see cause this model can be accessed by up to 50 at the time ..but the rights are enforced by admin ..and there is a ep category filter ..that those pc-es that didnt see it may just be included into..or ...might have a range of IP's once acurate ...and now its not up to date anymore cause of aditional adding of units ...ar other things like this
Was this helpful?
Yes
No
Popular Solutions for Web Cameras
Questions and Unsolved Problems for Web Cameras
Answer
can you suggest an inexpensive webcam for iBook G4 that has downloadable software?
Answer
What is the order of wires [colors] from left to right of Intex night vision IT-105WC web cam?
Answer
i need the power supply / cord for the vizcam 1000
Answer
The picture starts out fine and there after the picture has lines across it making it difficult to... (More)
Answer
T52his 52s what I 52get when I 2type something on52 the52 Genius 52k52ey52board
Describe your Web Cameras problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Web Camera Experts
Top Computer & Laptop Repairmen
in Baltimore, MD
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
