Xerox workcenter pro 123 errors
I have the above printer,it has set for awhile and after turning it back on it started to smoke from the fuser,it like burnt the wheels so they now have flat spots on them and then reported error 010-320 can you shed any light on this error and tell me f or where I can locate one of these fusers for less than $500.
    Scholar:
  • 53 Answers
Nasty one ,that!
010-320 is an overheat code, which i'm sure you know.Possible cause could be sheet of paper gone under the temp control thermistor This causes the temp to be sensed incorrectly , but the overheat thermostat should have switched it off earlier,
So..you will need new heat roll and pressure roll, possibly thermistor and thermostat, so your idea of a replacement fuser is the way to go...can't help you there
point to watch for...it is possible the SCR that supplies the power to the fuser is faulty, it would therefore take out any new fuser you install ( incidentally you may also need a tech to clear the 010 code if it stays locked in...not good news, sorry!
Posted on Jan 26, 2008
Xerox 7242 error 010-328 i have a xerox workcenter 7242, it is giving me error code 010-328. how can i fix this error please
That error points to a fuser problem. Replace the fuser and see if that works for you. If not then you need some add'l parts and a service tech to install and repair it for you. Hope this helps.
Sep 03, 2016 | Xerox WorkCenter Office Equipment &...
I have replaced everything on my 123 but it still jams
Is it jamming at the fuser? the most common problem is the fuser exit sensor that is located behind the fuser on the frame of the machine. Can you provide more details or an error code?
Oct 06, 2014 | Xerox WorkCentre Pro 123/128 Printer
Xerox work centre 4150 screen states faulty fuser module. Can't seem to find part...Help
That is in fact a bad fuser which must be replaced (part# 126N00321 for 110v). Replacing it is simple, open the right door and remove the 4 screws that hold in the fuser. Make sure the machine has been off for awhile because the fuser my be hot. Here is a video that shows you how. Hope it helps, and thanks for using fixya
Dec 20, 2010 | Xerox WorkCenter 4150 Black and White...
Hi i have a Xerox work centre workcenter m15i which when it turn on, it display heating Error.what could b the problem.assist
Heater quarz lamp is blown/cut. You can access it by removing the right side back vertical panel, removing a connector and four screws. You can pull the whole fuser assembly out very easily.
There is no spare part for the lamp itself. You must replace the fuser unit (which contains the lamp + thermostat).
Sep 15, 2010 | Xerox CopyCentre C20 Black and White...
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
May 02, 2009 | Xerox Office Equipment & Supplies
I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Jan 25, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox workcenter pro 765 error 22
That is a fuser not reachine tremperature fault.
Most likely the fuser will need replaced.
Go to google and type in "the parts drop".
Call Britt and he should be able to fix you up with that part for a fair price.Just tell him the model number and code.
Aug 18, 2008 | Xerox Office Equipment & Supplies
1,664 people viewed this question
k24674
jasbo
jasbo
