Home | Kenmore | 50522 / 50524 Side by Side Refrigerator | Layed refrigerator on ...
Kenmore 50522 / 50524 Side by Side Refrigerator
Problem for Kenmore 50522 / 50524 Side by Side Refrigerator
Layed refrigerator on its side to move waited 3
By gyarnes on Nov 02, 2009
layed refrigerator on its side to move waited 3 days plugged it in worked fine for 3 days then electrical smell and it doesn'tget cold. can i fix it
Best Solution
posted on Nov 02, 2009
Very Helpful)
jackfrost555
Rank: Guru  Refrigerators  Expert
Rating: 93%, 66 votes
Fan motors are great item to give off a burning smell when failing.
You have one in the freezer compartment behind the back panel.
You should be able to hear it when you open the door to the freezer.
A second motor is behind the cover panel at the bottom rear of the machine near the compressor. Failure of either motor can cause no cooling, and a burning odor.
There is a calrod heater located in the freezer compartment behind the real panel that can short and burn, but it would not immediately cause rapid cooling failure unless it burned a hole in the evaporator causing a total loss of refrigerant. ( I've seen it happen, but it's rare). Beyond those items wiring runs throughout the machine and can be suspect especially if the machine was transported on it's side. Refrigerators should always be moved in an upright position.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenmore 50522 / 50524 Side by
Questions and Unsolved Problems for Kenmore 50522 / 50524 Side by
Do you recommend Kenmore 50522 / 50524 Side by Side Refrigerator?
Answer
Answer
My side by side refridgerator/freezer stopped working. Neither side will cool.
Answer
My Kenmore Ice maker produces Ice just fine, but I end up getting a big clump of stuck together ice... (More)
Answer
Leaking water from the bottom. The water pan was full. I turned off the water and the leaking... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 50522 / 50524 Side by...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
