Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Problem for Honeywell Electronic Programmable Heat/Cool Thermostat -...
Old wiring looks like this
By leahnpc on Nov 02, 2009
yellow =y1 green =G white=w2 orange =O blue=C red=R installing a Honeywell RTH7600 where does the orange wire go we have a heatpump.L
Solution #1
posted on Nov 07, 2009
Not Rated)
acfxr
Rank: Guru
Rating: 90%, 63 votes
If you have a heat pump, the thermostat that will operate it most generally will have an "O' terminal for the orange wire, this is the circuit that energizes the reversing valve on the heat pump, be sure that the stat says heat pump on the box. hope this helps
Was this helpful?
Yes
No
Popular Solutions for Honeywell Electronic
Questions and Unsolved Problems for Honeywell Electronic
Do you recommend Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater?
Answer
Answer
replacing my intermittent pilot module (S86H1006) with the universal S8610U. my original module has... (More)
Answer
the heat will not come on. Checked the fuse and replaced batteries - the air and fan work. I have... (More)
Answer
I can't seem to adjust the heat setting above 55 degrees on my Honeywell TH5220D thermostat
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Electronic...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
