Solution #4
posted on Aug 09, 2005
Rogers - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
: I don't doubt your experience, but I one big question.
So Eric, you still don't doubt his experience?
It's not that he wasn't here and therefor unaware of your question.
: How to the lift the heads in a 3.5" drive? I know how it was done in ancient
: large oxide drives, but there is so little room in modern drives to add such
: mechanics.
: If the heads lift on spindown, how can they stick? I assume there must be
: design or firmware bug that fails to move heads to the landing (takeoff?)
: zone.
: : !Folkert, your true colours are exposed once again, buy a bridge, sit
: underneath it and jump out and charge people when they want to cross :O)
: Some drives do not Identify if they do not pass POST tests, some drives will
: only identify part of there model number (this is because they cannot read
: media capacity ), I will check next week and post my results if you wish
: Folberk!
: | IBM 75 GXP use unload load technology.
: | Load/unload (L/UL) technology eliminates contact start/stop stiction
: | and not stiction, which can happen when the drive is spinning down or
: | if power is cut. The L/UL type drives do not have textured areas on
: | the disk, as there is no landing of the heads on the media, this can
: | make a lovely smooth surface for stiction. Due to the fact that the
: | heads do not land on the surface a much thinner layer of monolayer
: | (and sub-monolayer) films of perfluoropolyether (PFPE) liquid polymer
: | lubricants can be used, this coupled with high temperatures in the HDA
: | can evaporate, contamination like water (Humidity) and oxygen can have
: | a bad effect on the carbon layer (bonded to the lubricant which causes
: | irregularities on the media) (Hungary plant may have a problem. Who
: | knows?), and can again cause stiction. Also as the fly height reduces,
: | the amount of current (And switching speed) that is channeled through
: | the GMR (Etc???) head increases, which heats and slightly vibrates the
: | heads/media (Can crack the heads), another reason for
: | headcrash/stiction! So if you take into account all of the above
: | tribology implications and information you can make your own decision.
: | A hot HDA, coupled with decreased fly-height and a smooth surface is
: | a perfect environment for stiction (Suction of the two surfaces
: | together, very much like two panes of glass pushed together) You can
: | identify stiction by faint square marks on the media, normally only in
: | one place on each surface, the marks are caused by the sliders that
: | the heads are integrated into. Hope this info helps. Obviously Folberk
: | and Robot Ron know all this, so have learnt nothing :O)!!!!!!! I will
: | post a picture of the 75GXP when I have one with stiction, quite soon
: | I think!! :Op
