-   i've replaced my broken screen that worked fine before it broke and i know i didn't break anything while i replaced it now the screen is white but still takes pictures and everything.-   Guest
Mar 27, 2009
-   turn camera on & either the screen just stays blank white or it blinks white once then goes black, but the green light stays on. I can get it to take pics but i cant tell what the hell im doing till i take tha card out of the camera & download the pics on my p.c. -   onceloved
Mar 01, 2009
-   Same here tire ribbon cable fix didnt work gonna try again
What happened is the lcd ribbon has loosed up or came off altogether.
Try this;turn camera on,squeeze case between your fingers,where sony
logo is,if ribbon is just loose the lcd should come back on. If this
doesn't work,take it to a local camera shop and have them fix it,it's a
very simple fix.
i just had this problem and it was the LCD ribbon was dirty so i took the camera apart and diconnected the ribbon inside and then reconnected it now my camera works fine
I left the camera dock 2 pluggef in while I was unistalling the software now the dock won't let me charge the battery should I throw it away or can I fix the problem
i cannot install the canon software on my macbookpro because apparently there is 'insufficient...
(More)
i cannot install the canon software on my macbookpro because apparently there is 'insufficient screen resolution.' how can i fix this?
I did not realise that my camera had been left switched on and the battery ran flat. Now my lithium...
(More)
I did not realise that my camera had been left switched on and the battery ran flat. Now my lithium ion battery will not recharge properly... why might this happen? I do hope this is only a problem with the battery no the camera... Thanks for your help xxx
i have the dsc-s500 that only stays on for a sec hen turns off....I ran thru 4 ets of batteries with...
(More)
i have the dsc-s500 that only stays on for a sec hen turns off....I ran thru 4 ets of batteries with the same result. Should I just give up and tash it? In this economy, I cannot afford "new luxury itms."
Camera reviews pictures and live video on memory card without problem, but in picture taking mode screen turns white when you turn on camera, have tried removing and replacing batteries - installed new fully charged batteries, removed and replaced memory card, have left in off position on dock station, tried batteries in similar model camera to ensure they are fully charged - also a Kodak-. --CW330 model. Have tried adjusting exposure compensation, white balance and tried adjusting ISO speed - still the screen remains white when powered on - camera worked perfectly until recently - has not been subjected to heat/cold water or other harmful environments, camera is less then 1 year old. Please advise! I use this camera for work as well as pleasure and need a solution quick! Thanks!
screen is white and I cant take pics, i can veiw images on card but cant take any photos
Comment by Guest, posted on May 29, 2008
Finepix F31fd Screen suddenly went white- can still see menu's etc but cannot take photos or videos (though sound on video mode still works) screen remains white. Taken memory card/battery out- tried transferring the white pictures onto my computer to see if they had taken but they came out white too. Tried messing about with the functions but nothings happening- it's just all white!!
I'm having the same problem. When I turn on the camera, the LCD screen remains white. It doesn't appear to be cracked.. It's the backlight that remains lit, but no screen.
