GE Zoneline AZ55H07D Air Conditioner
Problem for GE Zoneline AZ55H07D Air Conditioner
My ptac is blowing out warm air instead of cool
By andromeda241 on Nov 02, 2009
my ptac is blowing out warm air instead of cool air...what is the problem. the air conditioner is on and the compressor is running...
Solution #1
posted on Nov 03, 2009
Not Rated)
flatech
Rank: Guru
Rating: 97%, 15 votes
May be low on refrigerant, May want to pull out the unit from the window and see if you see any oil spots anywhere, inside where the coils are at or around the compressor area where copper is located.
If so you will need to call a local Ac company to repair the unit.
Good luck friend.
Was this helpful?
Yes
No
Popular Solutions for GE Zoneline AZ55H07D Air
Questions and Unsolved Problems for GE Zoneline AZ55H07D Air
Do you recommend GE Zoneline AZ55H07D Air Conditioner?
Answer
Answer
can some one help looking for operation manual for amac 12000 portable a/c unit
Answer
Thefan motorwarms up but does not runs
Answer
i have a 30 gig zone that what charging in my truck and my dog bit the wire in half ever since it... (More)
Answer
GE Zoneline HP PTAC A3B688DAALW1 WIRING DIAGRAM? Found a 6" L white wire with 1/4"F... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Zoneline AZ55H07D Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
