Question about HP LaserJet 4350dtn Printer
Service error 49.4C02
Can you tell me what this means?
  • 1 more comment
  • ogueyungbo Dec 05, 2008
    I have problem with Hp 4730 mfp printer
  • John Smith
    John Smith Mar 02, 2018
    you need to contact hp printer support
    Hp printer Support number 877-690-9305
  • Chimezie Umeibe
    Chimezie Umeibe Jan 29, 2019
    change the logic borad
    New Friend:
That means your driver is out of date. This software driverupdate us usually keep my drivers up to date (perfectly)
take a look
Posted on Oct 27, 2014
  • 417 Answers
Yes it can be a number of things. It normally means data error. Then first thing you should do is delete the printed jobs within the driver. Turn the printer off then on and hopefully this would be it.. If it is try printing the same document again if the same error message appears then that document is corrupted.
If the problem doesn't go away then you turn the machine off remove the additional memory then turn back on. Then hopefully the error will not be there.
If still there then the printer formatter board firmware is corrupt and will need to be uploaded. This is a return to HP option though.
Hope the first one works
Thanks J
Posted on Jan 07, 2008
  • 184 Answers
Paper jam is what prompts this error.
The 49.4C02 error usually follows a paper jam. When ever you close the primter door after clearing the jammed media from one area of the printer, the control panel immediately posts a 49.4C02 error. Often, you might power cycle the printer and it will hang at Checking Printer. For the 49 error to occur, additional media must still be stuck in the paper path.
Firmware version 5.005.3 contains a fix that allows the printer to recover and notify the user of the location of the additional jammed media in the paper path. if you are experiencing this issue, you should update to the newer firmware. This version of firmware also fixes the issue with the printer hanging in Checking Printer.
Posted on Aug 27, 2009
  • 3 Answers
This is a Fix that has worked for us, so far:
To "deleted a suspect print job" is not really a fix as the next corrupt job will cause the error again. I don't think anyone knows exactly what is wrong with the job either. I noticed the problem when we upgraded past Adobe Reader 7 (versions 8 and 9).
Last year we fixed this problem on HP color 46x0 and 4700 printers by replacing the 615n card (which has had a lot of problems, but that is another thread) with a 620 card.
I have over two hundred 4100 series through 4300 printers in use at my company. A couple of months ago we had 4 of these 49 errors fixed by having the system board replaced under warranty. We noticed that the replacement board had and older firmware installed. I have been very good at keeping up with updating firmware, so all my HP printers have the latest image.
Some may suggest to install the "latest versions of firmware" for the printer . ." This is what we found to be the problem. All of my 4250 printers have firmware 20080319 08.015.0 installed. When users reported the 49 errors on 4 printers a couple of weeks ago I installed the 2007 firmware image on them. In two weeks, none of these printers have had the problem. If you remote into the printer and look at the Event Log, you can see how often this error occurs. I was seeing it happen about every 50-100 pages. I have over 4,000 pages now without a problem on the printers the older image was installed on. I just did 2 more last night and plan on doing this to all over the next month.
Posted on May 07, 2009
  • DavidMaurice May 29, 2009
    I have been fixing the 49 error on multiple printers by installing the older firmware image. Got a reply from HP support to verify my fix.
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    I was able to find the old firmware on my PC. I copied them
    out to the Filefactory where you should be able to download them from. Let me
    know if you need anything else. Here are
    links for HP LJ 4100, 4250 & 4350, and 5500
    Filename: lj42x0fw_08.014.0A.rfu (16226.79mb)
    Download Link: http://www.filefactory.com/file/agf71ce/...
    Filename: lj4100mfpfw_03_801_1.rfu (11112.57mb)
    Download Link: http://www.filefactory.com/file/ag2913f/...
    Filename: lj5500fw_04.019.4.rfu (12188.5mb)
    Download Link: http://www.filefactory.com/file/ag2973e/...
  • 22 Answers
There are a couple of things that could cause the error:
#1) Bad HP 615n jetdirect card. HP has had a lot of these cards go out. Do a cold reset on the card and reconfigure, may solve the problem.
#2) Driver issue, PS or PCL? Try changing from what you were using. PS usually works better with Adobe products (like PDF documents.
#3) For PS driver printer.
1. Open printer Properties.
2. Go to "Device Settings" tab.
3. Disable the option "Postscript Passthrough" under the "Installable Options".
Posted on Jul 23, 2008
I had the same problem, i loged on to the print server, deleted the job and restarted the print spooler service. When i restarted the printer I manualy canceled the job and that resolved my problem :)
Posted on Sep 29, 2008
    Problem Solver:
  • 5 Answers
It is most likely caused by a print job, so the first thing you need to do is to delete any jobs in your print queue.
One way to determine if its a job is to power off the printer disconnect whatever cable you have it connected to the outside world by and then power it back on and see if you still get the message.
Posted on Nov 15, 2018
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • HP Expert
  • 35 Answers
Service error 49.4C02 - hp printer support -1-31hygl30hjwh2qatbhqfcd3j-5-0.jpg
Support For Hp Printer Call Toll Free 877 690 9305
Posted on Mar 02, 2018
  • 27 Answers
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device. If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Posted on Dec 03, 2014
    New Friend:
    Problem Solver:
  • 5 Answers
Formatter board....should be about $90 with exchange.
Posted on Nov 08, 2014
Updated the Firmware &^ CHanged to PCL 5C Driver. Worked A Treat, PCL can handle thing such as PDF, better than PC.
Posted on Oct 30, 2008
How to remove memory
Posted on Aug 10, 2008
Well did it fix it or what?
Posted on Jun 03, 2008
SOURCE:
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 154 Answers
SOURCE: Hp CM8060 error code 49
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
xcanox
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
  • 17 Answers
SOURCE: problem with our printer 5200tn
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt data
during transmission to the printer. Other
causes include poor-quality parallel cable,
poor connections, or home-grown programs.
On rare occasions, the formatter is at fault
which typically appears as a 79 Service Error.
  1. Turn the printer off and then on.
  2. Press Stop to clear all print jobs from the printer memory.
  3. Turn the printer off and then on.
  4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message
only appears when using
certain software programs,
contact the software program
vendor for assistance.
Posted on Dec 18, 2008
pdouglasss
  • 125 Answers
SOURCE: hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
occurred that caused the
to abort operation. This type
of error can be caused by
corrupt data, or invalid
can corrupt data during
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Posted on Jan 10, 2009
Impressa s7 error 6
Take it to Autozone and they will run a test on it, as long as your SERVICE ENGINE LIGHT IS ON. They can tell you what the code means and its FREE!
Dec 06, 2011 | Coffee Makers & Espresso Machines
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Verifone vx610 decline code 248
This is tricky to answer... different processing service use different codes. If the software you are running is built on a St. Pete's platform, this code means that the transaction you were processing was a 'reversal' (void) and the amount entered didn't match the original.
If you were running a sale and received this code and the display or receipt actually printed "declined" - it is a valid response indicating the customer card was declined and the code tells the service rep at your processing center why it was turned down (over limit, high risk, frozen account, etc...). If the response did show the word "declined", you can call your customer service department for your processor and they should be able to tell you what the code means in their system. If they don't - change processors as this is a standard service.
Aug 25, 2009 | VeriFone VX510
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
or home-grown
programs. On rare
Error.
the printer memory.
then on.
different software
program. If the job
the message appears
only with a certain
software program or
software vendor for
assistance.
or computer.
6 Remove all memory
from the printer.
DIMM and EIO device
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
"Service Req E095"
This is an HSYNC Error and probably means the Laser unit on your machine is faulty.
Possible causes of the error :
Laser Scanner
LSU Harness
C585 Main MCU Board
For more info get a service manual HERE
May 28, 2008 | Epson AcuLaser 2600N Printer
I Have a Xerox colour printer 621 and getting the error message (power off, wait 5 seconds then switch on (15-384) or call for service quote on the above fault code) what dose this mean?
Your printer power supply internal is not proper, get help from service provider by telling them error code (15-384), if possible they will try tell u solution online or will attend the complaint.
Apr 02, 2008 | Office Equipment & Supplies
Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Jan 25, 2008 | Minolta CF2001 Copier
Machine code question
Hi Alexandra,
I hate to be the messenger of bad news but Machine Error 7C mean Engine PCB Error. This error code is for servicer reference and may not appear on the service manual. If it does, it will tell you to unplug the unit and try again. If the problem persists, you have to bring it to an Authorized Brother Service center for repair.
The link below will take you to a Service Manual page where the error code is defined.
http://tinyurl.com/yvcv35
Best Regards,
Jan 15, 2008 | Brother IntelliFAX 4100 Laser Fax
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
HP LaserJet 4350dtn Printer Logo
66,153 people viewed this question
Clive
Clive
Thomas F. Schneider
