Question about SanDisk Sansa e250 MP3 Player
Erasing bad music on my player
I have some corrupted songs on my Sansa and when i plug it in, Windows does not show that the songs exist on my player. But when i turn it on they are still there, they just take up space. Is there anyway way to just clear my whole library and start over?
  • 2 more comments
  • snake08 Jan 04, 2008
    the music on my mp3 does not show up on my computer
  • rekath Mar 22, 2008
    I have the same problem have tried the following steps, not showing?? is this compatible to vista?
  • Kaileigh7 Mar 23, 2008
    I have the same problem, but when I right click Sansa e250, there is no format option ..
  • Habiebm2 Mar 23, 2008
    I have the same problem, and 'format' does not show up.
    Some how I got some corrupted/infected files onto my Sansa and it's been causing problems from, not shutting off, no turning on, freezing up, and not letting me delete said files. Does anyone know a quick and easy method to completely wipe out my Sansa?
After some playing around with the thing I ended up not having to completely wipe it out. I just had to get the newest firmware from the Sandisk website. So I'd try that #1.
In addition, I've figured out how to get "format" to show up.
1.On your Sansa go to 'settings' from the main menu
2.Change the 'USB Mode' to 'MSC' [This was why 'format' wouldn't show up on mine, or so we think]
3.Open "My Computer"
4.Right click "Sansa e250" and select "format..."
5.Check "quick format" and run
That should work hopefully.
Good luck.
Posted on Mar 24, 2008
    Problem Solver:
  • 18 Answers
If you're fine with erasing your whole library, then just format the player. Connect the player to your PC:
1. Open "My Computer".
2. Right click "Sansa e250" and select "format..."
3. Check "quick format" and run.
4. Reapply the firmware from the sandisk website.
...and you're done. the sansa will be totally wiped clean. and now that you have the newest firmware, you shouldn't see this problem again.
Posted on Jan 04, 2008
I can't delete songs off my sansa e200! HELP!
When you plug the device into your computer just look at it with the file manager. If you can't see the media files, make certain you have selected in windows "show all files". You need to see the hidden files, including operating files. Be very careful only to delete files that you think are the corrupted media files.
If you are on windows 7 you can look at my blog site which will explain how you can select the options to view all files.
It's under the section about windows media player art problems.
http://therealchart.blogspot.co.uk/p/technical-help-tips.html
May 08, 2017 | SanDisk Sansa e200 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
Some songs i added into it won't show up in player
Delete all the songs on your device and transfer them back..You could have a corruption in your databasse...
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
Thank you
Computerrep
Dec 22, 2008 | SanDisk Sansa e260 MP3 Player
Sansa bad track
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media1.gif, music and delete them from there.
Either under sync pane in windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
If you still not able to delete it let me know so I can have you try something else...
P.S.Please rate accordingly...
Thank You
Computerrep
Mar 21, 2008 | SanDisk Sansa E280 MP3 Player
Sansa keeps shutting off/ wont read memory disk
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e260 MP3 Player
Problem with my sansa e200
Jan 17, 2008 | SanDisk Sansa e200 MP3 Player
Formating issue
SALE UN MENSAJE QUE NO DEJA REPRODUCIR ALGUNAS CANCIONES
Nov 21, 2007 | SanDisk Sansa m240 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
BAD TRACK FOR EVERY SONG
Hi tooky. Getting a "Bad Track" message on the E250 may be an indication of memory corruption, music file corruption, or outdated subscription/license info. One solution would be to format your player in Windows Media Player (version 10 or 11): 1. Make sure your player is in MTP mode by navigating the menu as follows: Menu > Settings > USB Mode You would get a choice of "MTP" or "MSC". Please select "MTP". If your player is an "E250 Rhapsody series" player, select "Plays for Sure". 2. Plug your player to your PC and run Windows Media Player. Click on the "Sync" tab and make sure the E250 is listed. Look for the "Format" button (it would look like a "pencil" on Windows Media Player 10) and click on it. Follow the on-screen prompt. 3. Re-load your songs by either copying/pasting your songs to the player or by using Windows Media Player's "Synchronization" feature. You could also format the player while in "MSC" or "Rhapsody" mode by browsing the player in Explorer, right-clicking the drive letter corresponding to the player, then select "Format". Follow the on-screen prompts Another solution would be to update the firmware of your player by downloading the Sansa Firmware Updater using this link from the SanDisk website (instructions are found on this site as well): For standard E250 or E250R "Rhapsody Series": http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Make sure your player is set to MSC mode, or "Rhapsody" Mode The type of music file might also be the cause. If your music files are licensed, purchased or acquired via subscription, you may want to contact the provider for more info on how to re-download the music files. I hope this helps. There are other procedures available but these might actually make your player work normally again. Hoping for the best :)
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
